Old 06-10-2009   #31
Default Re: Ready for the oil catch can...
Originally Posted by Aurora40 View Post
I also thought more about pouring the oil back into the engine. Since the PCV system is intended to remove blow-by from the crankcase, I'm thinking the oil will be loaded with gas and such. So I think it's probably best to just pour it out.
On the other hand, where would it have gone w/o the catch can?
Also, man I wish the fittings weren't copper/brass. Silver would have been a lot better. I may try painting them black.
Just a thought...Using a propane torch and some silver-solder you might be able to "tin" them, and then polish them a little. I'm not sure what would keep them from tarnishing later, but maybe a squirt of clear coat or maybe just some silicone spray on a rag would work as well.
P.
Old 06-10-2009   #32
Aurora40
Aurora40's Avatar
It would get combusted. It wouldn't go back in the crankcase, I don't believe.
Old 06-12-2009   #33
TommyL
Also, man I wish the fittings weren't copper/brass. Silver would have been a lot better. I may try painting them black.[/quote]
Powder coat would work very well and you can pick any color you like I think I will add a catch can to my 90....seems like a great addition.
TommyL is offline   Reply With Quote
Old 03-23-2011   #34
Is there another method of pulling the oil rather than seperating the hard line like Bob did here?
Old 03-23-2011   #35
Powder coat would work very well and you can pick any color you like I think I will add a catch can to my 90....seems like a great addition.[/QUOTE]
-=jeff=- style catch can he currently is using now has silver/chrome fittings available. http://www.eliteengineeringusa.com/Catch_Can.html
Old 03-23-2011   #36
Here is the picture i had on the first page (I fixed the image there too)
Look in the bottom right of the photo the 2 darker bolt heads are the mounting bolts i drilled holes for to install the catch can
Old 03-23-2011   #37
Thanks Jeff now I see how you did it. I like that better I didnt want to cut the hard line.
Old 03-23-2011   #38
Just in case any one is interested in the catch can made by Accurate Machine Works, aka accuratemachineworks.com here is a link to who sells them as you can't buy it from the AMW website.
https://vastperformance.com/index.ph...ch+can&x=5&y=9
AMW website link also:
http://www.accmachtech.com/catchcans.asp
fwiw. I kind of like the undercuts that AMW puts in their unit vs a straight machined receiver cup. JMHO
Old 03-23-2011   #39
Aurora40
Aurora40's Avatar
There's a hard line at the plenum (or a rubber block on '90 cars), and the rubber F-piece on the PCV valves. You could easily just attach something to those and run your own lines, like Jeff did. I believe that's basically what Locobob also did.
I just thought it was cleaner looking to cut the stock pipe, but it certainly isn't necessary. I also, at the time, didn't think I'd ever sell the car...
Old 03-24-2011   #40
There seems to be a choice on the Elite Engineering Web site......exactly which catch can (anodized silver) did you get? C5 (1997-2004), 2006, LS2 and C6 Z06 Or....C6 (LS3)?
Did you modify the stock mounting bracket that came with the catch can?
Very nice setup
what is the difference?
