My 95 came with the vortex air intake, is this a good unit? I'm not thrilled with the looks of it and it looks like it could have been mfg. a little better. I know I'm being picky here, but it is my one and only Z. Only other mods on the car are B&B exhaust and B&M short throw shifter. Will the stock unit with a K&N be just as good? The car has the stock chip in it, should this be upgraded also? I"m new 2 this game so I'm still trying to learn all the rules. Thanks, from a rookie. Rick
![]() Join Date: Dec 2003
Hi Rick,
A couple of quick points. The vortex, if it is the one I am thinking of has not been proven to increase HP by anyone on the forum that I know of. A few of them liked it for the look, or for the sound they felt it had, but no dyno numbers to show any increase. Maybe this thread will bring new info on it. Many have come to the conclusion that the stock intake with a stock or K&N filter is as good as you can do without permanent modification, aka forced air. As to the chip, the more mods you add, the more the chip would be needed. On your ZR-1 it can help some if you want to disable the CAGS, keep it running a little cooler, etc., but it will not be a seat of your pants type of mod. As you can see from the poll, there are many choices, and while most tuners chips do similar things, there are differences. http://www.zr1netregistry.com/forum/...read.php?t=852 ![]() |
Can you take a picture of it? I'm just curious what it is, never heard of it.
It is garbage, pure and simple. The clear housing collapses and doesn't seal anymore.
I am assuming this is what you are referring to.
http://www.ecklers.com/product.asp?p...dept%5Fid=1758 |
#6 | |
Stock with a clean paper filter or K&N is the only way to go. I think I have a spare stock one if you need it
#8 | |
if you don't have a reinforced air duct on the car I suggest getting one. I think that the air duct has been discontinued by GM and I may have a spare that I can sell you if you need it.
#10 |
![]() Join Date: Jan 2004
Used to have a Vortex: Good idea, very poor execution. Mine warped and cracked all over. I also suspect it was a restriction on my 368 - the duct necks down to a 3in id circle where the filter slips on, my throttle body injests air through two 2 1/2in circles.
