Old 05-17-2009   #1
Default Fans come on with key in "on" position
My fans are coming on with the key in the on position but not started...kind of like when you run a diagnositic on a car.
Bad relay?
Old 05-17-2009   #2
Pete
Pete's Avatar
Default Re: Fans come on with key in "on" position
Is the chip in correctly.
Grounded relays.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 05-17-2009   #3
Bad relay?
This hasn't happened before? Is this the red car or the black one?
If the check sum has been disabled, fans will come on.
Old 05-17-2009   #4
Relays are fine, swapped with the 90...this is the 92......took it for a drive....damn, now I remember why an 1800rpm lanch is needed!
Fans are still coming on though
Old 05-17-2009   #5
tpepmeie
say what?
Usually if the fans are running and the idle is high, you've got a PROM error. I think a code 51, or something. A bad burn, or wrong checksum will cause this, or the prom not seated properly.
Is the check engine light on, or "sys" displayed in odometer window?
Todd
Old 05-17-2009   #6
Grounded relays.
Pete
I agree if the PROM inserted wrong the fans will come on immediately
Old 05-17-2009   #7
System reset itself..no more issues
