![]() Join Date: Oct 2007
The attached photo shows the location of what sounds like a vacuum leak.
The metal tubing is inserted into a rubber hose. Is this a problem ? Vince 90 red/red #1966 |
![]() Join Date: Jul 2005
The rubber piece fits 2 hoses. I replaced mine with 2 separate hoses and haven't had a problem since.
#3 | |
![]() Join Date: Aug 2006
Not knowing exactly which one is leaking (there are two) and how severe the leak is, it's tough to assess it's effect on performance. One thing I do know is that LT5 is very sensitive to vacuum loss especially for 2ndary actuation. If it was mine I would pull the plenum and replace the piece and check all vacuum lines, check 2ndary actuation, tighten up bolts around breather box (?) and button back up. This article should help if you are new to this. http://www.corvetteactioncenter.com/...8/002/article/ |
![]() Join Date: Dec 2003
http://www.corvetteactioncenter.com/...8/002/article/ This is a very good detailed article and kudos to Rob over at CAC for making it up for all to see when one is chasing down a vacuum leak. We like the visitors and the end photo! |
Shoot me an email, I have the piece brand new.
