Old 04-28-2009   #11
Aurora40
Aurora40's Avatar
Default Re: FX3 Selective Ride Control
One of the ALDL pinouts is the ground. I believe it is the "A" pinout, or the upper right one when looking straight at it. You can use a short length of wire or a paper clip to ground whatever pin (C in this case) to it.
Bob Saveland
Former owner of #2517
Old 04-28-2009   #12
max76
Yes Aurora,the A pin is the first on the right upper....I must do this operation with the key turn at first position?
Thanks again
max76 is offline   Reply With Quote
Old 04-28-2009   #13
Originally Posted by max76 View Post
OK tom, i must put a cable to pin "C" and the "-" pole of the battery (or the body vehicle) for 3 times and evry time have 2 seconds of duration. It's right?
Thank you
Max
Max, sorry for not being complete! My bad.
Yes as Aurora40 said you can use the "A" pin in the ALDL as it is the system ground. Or if you wish you could use the seat track as a place to ground on to.
Old 04-28-2009   #14
max76
Tom, no problem...i have done the test and now the chip is clear...i also control the actuator and when you turn the key in first position the actuator gear move it.
In next days i'll try the car and i can say if there is some other error.
Thanks for the moment!!!!
Max
Old 04-28-2009   #15
Jeffvette
Max
Max, an error will show up immediately, as the system self checks at the key on position. So if the light is currently out, you have no codes.
Old 04-28-2009   #16
max76
Thanks Jeff,
But the shocks (for me) are so much soft. If the controller is in tour the shocks are soft (with the car stop)OK??
If i turn the controller on perf and i push on the hood the shocks are always soft too, at the same way...
I think that my shocks are toast...what do you think??
Max
Old 04-28-2009   #17
Jeffvette
Thanks Jeff,
Max
The shocks are a progressive system. When parked, the settings are on the softest setting. The big thing is when driving at around 160 Kmh, does the front end seem to float around? But as the shocks age they do deteriorate even when not in use.
Old 04-28-2009   #18
gbrtng
gbrtng's Avatar
Thanks Jeff,
Max
The controller makes the shock settings stiffer every 20 mph speed increase.
Checking the shocks with the vehicle stationary is not a good test as you have found.
Old 04-29-2009   #19
max76
Ok guys...Today is a sunny day here, after a week of big rain...i'll try the car in next days, i think that my shocks are toast also if the Z have low mileage, but always 20years!!!
Thanks at all for the HELP!!!!!!
Max
