Old 04-06-2009   #1
rhipsher
rhipsher's Avatar
Default Finally arrived.
I thought I was going to be a senior citizen by the time this disc arrived.
So tomarrow I'll get the fluted pilot bushing and get longer grade 8 a bolts from Fastenal. Then start putting Humpty Dumty back together again.
I must admit the duel mass flywheel is a fantastic well engineered piece of equipment and has served me well. It was quiet. Always made the car idle super smooth. I still don't understand how you could get a nickel to stand up on it's side on any surface. But I digress.
But out with the old. In with the new.
This Fidanza weighs no more than my 17" laptop.
And the Center Force sprung hub disk. $325 for the Fidanza. And $198 for the Center Force disc. We'll see how it goes.
Old 04-07-2009   #2
jonszr1
jonszr1's Avatar
Default Re: Finally arrived.
rick i know you are going to love the way the rpms get up there a ton quicker .you will need to a just a little rpms when leaving from a stop light . so how your new shoe??????????
Old 04-07-2009   #3
flyin ryan
flyin ryan's Avatar
Yup...no inertia advantage anymore.
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y.
Old 04-07-2009   #4
rhipsher
rhipsher's Avatar
Yup. I know all about it. Not enough gas from a stand still and the car dies. To much and you light em up. I'm sure it's gonna take some getting us to.
Old 04-07-2009   #5
jonszr1
jonszr1's Avatar
you will take to it like a duck to water ,kinda like when you drove farrah and got her just a little sideways
Old 04-07-2009   #6
rhipsher
rhipsher's Avatar
Dude Farrah would piss a Zo6 off.
Old 04-07-2009   #7
Jerry#397
Jerry#397's Avatar
Rick, You haven't mentioned the pressure plate, which brand did you use and the price? Thought one had to have a "matched set" (pressure plate and disc) is that no longer true?
Thanks,
Jerry
Jerry#397 is offline   Reply With Quote
Old 04-07-2009   #8
rhipsher
rhipsher's Avatar
Thanks,
Jerry
I'm using the old clutch/preasure plate. It only has 8,000 miles on it. I wanted to go with a spec stage two clutch. But they are about $500. I don't feel like having $1,000 bucks wrapped up in a clutch/flywheel/clutch disc. If I were running 500+rwhp then I would. But I'll be running around 400rwhp when I'm done with the same mods most of the guys on here have already done.
P.S I also went with a stronger throw out bearing.
Old 04-07-2009   #9
USAFPILOT
USAFPILOT's Avatar
Hey I am off for a few days...you need any help bolting that up?
Old 04-07-2009   #10
rhipsher
rhipsher's Avatar
Sure! First I've got to get the fluted pilot bushing before I can start bolting stuff up. The dealerships in town won't get it for me until I pay the whopping $4.00. Only then will they locate it and send a driver to pick it up same day. Which means I've got to take off work early cuz they all close at 5:00pm. P.S Ryan since your off the next few days you should come on down and check out the shop. It's only a few miles from you on Persimon right off 2920 behind BJ services.
