Old 11-23-2005   #1
Patton
Patton's Avatar
Default Performance Chip Question
http://www.acsvette.com/chips.html
At Mr. Crowley's site, he mentiones the removal of secondaries as a feature in his performance chips. What the junk is that about? Anybody?
"Mr. President, we must not allowwww... a mine shaft gap!!" -General Buck Turgidson
1994 ZR1 - White on Black
Patton is offline   Reply With Quote
Old 11-23-2005   #2
Aurora40
Aurora40's Avatar
Default Re: Performance Chip Question
I believe he'll add programming to deal with the removal of the secondaries if you've done that to your car.
Bob Saveland
Former owner of #2517
Old 11-23-2005   #3
bobbyhi
bobbyhi's Avatar
Not being too mechanical, I don't understand the reasoning of removing the secondaries. I thought that was so special to the Z's.
Bob Anderson
1990 #2405 White/Gray
Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported
Minnesota State Director
Founding Member #19
Old 11-24-2005   #4
I think it is a case of having both injectors serving the fuel needs all the time. I believe Cliff, LoTu5, from London has this set up on a 418 cu in motor. I don't understand all of the theory behind it. I guess you eliminate all those secondary parts so they can't fail on you?
A thought...I would guess when the motor gets on the cams the transition is less dramatic? I mean nothing is blocking the air flow thru the other ports and the injectors are already adjusting the A/F ratio so the big power is just there all the time?? I'm wondering if those cars must feel like an old rat motor from the 60's & 70's? I once drove my friend's 396/350 camaro & it was way different than my LT-1. The 396 felt like a stump puller from way down low in the rev band where the sb needs to get some revs up before anything happens.
Old 11-24-2005   #5
The stroker engine's may benefit from removing the secondaries. Tuning is a fine tooth blade also.
For a stock CUI or even a 368 car removing the secondaries would probably hurt the car .
I'm more impressed with the top end car's putting out 420 + RWHP .
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 11-24-2005   #6
Patton
Patton's Avatar
My sentiments exactly... Thats my goal actually. Squeeze as much out of the top end/exhaust and other small things here and there without changing the displacement. Although im still alittle uneasy about porting for some reason, I just dont like the idea of taking metal off. Tweeks a nerve in me.
