Old 11-18-2008   #1
8upZR1
8upZR1's Avatar
Default ZR1 rear spindle removal
Over the next weekend Im planning on removing a rear spindle from my 1990 ZR1 and was wondering if anyone here has tackled this? If so are there any special tools or procedures to follow? Any advice on making the job easy? Any help would be greatly appreciated.
-Patrick
Old 11-18-2008   #2
gbrtng
gbrtng's Avatar
Default Re: ZR1 rear spindle removal
You'll need a T55 (size?) Torx bit for the three bolts inside by the u-joint.
The FSM spec of 164 lb-ft torque spec for the spindle nut was later changed to 200.
The FSM is helpful if you've never done one before.
Old 11-18-2008   #3
jonszr1
jonszr1's Avatar
i have put rear bearings in both my cars .i personally found it easier to just remove the whole housing to get at the t55 torx bolt otherwise its a tight squeeze. it takes about 2 hrs if you go slow and clean everything . an hr per side . not a hard job at all
Old 11-18-2008   #4
8upZR1
8upZR1's Avatar
sweet, I look forward to it then. Thanks for the info.
