Old 12-15-2003   #1
Anonymous
Default tire air pressure sensor
Has anyone ever had their tire air pressure sensor dislodge at 145mph?? It was a clear sat morning 5miles of clear flat road, it felt like I needed to feel the adrenaline rush of my 92 ZR-1. I cranked her up half way through 5th & my tire sensor broke loose within my tire and my car started to bounce around the road @ 140 +.. Well, I got my rush & a well needed forearm work out.. I called my local Chevy dealer and they back ordered the sensor for a cost of $130. Dose anyone have any recommendations on any aftermarket upgrades? Can this system be removed?Regards,WikdZR1
Anonymous is offline   Reply With Quote
Old 12-15-2003   #2
Anonymous
Default
Yes it happens in open road races. Best advice either:
A. Don't go 145. :-)
B. Remove sensors.
C. Hope it doesn't happen again.
Yes they can be removed but your LTPWS sensor light will be on all the time.
Old 12-15-2003   #3
Anonymous
Default
1990 QUASAR BLUE
ZR1MOM, This may be a foolish question, but can the SLTPWS light be programmed out with a chip mod? Sort of like how they disable CAGS or turn the fans on sooner. It seems as though most just pull the bulb. Just curious.Thank You,
Old 12-15-2003   #4
Anonymous
Default
Good question I have a DRM Chip and last night when I installed the new sensor my light flashes on the dash when I start up but then it goes out. I thought I would have to reprogram the system so that leads me to believe it is not active. I have since lowered my air pressure (10lbs) to test out the system & no warning lights.. Dose anyone know how to test to verify operation? 92 ZR1 #252
Old 12-15-2003   #5
Anonymous
Default
There is no way that I know of to turn off the light thru the prom. Most either pull the bulb or put a piece of tape over it. Try lowering the pressure 15lbs, the Low Tire light should come on within 30 seconds of driving. If not it does sound like the system is not working.
Old 12-15-2003   #6
Anonymous
Default
I spoke to soon, my TPS came on this morning comming to work. it now stays light with the correct pressure within the tire. How should I reset this is there a cal sequence?
Old 12-15-2003   #7
Anonymous
Default
Z Factor
Quote: from zr1mom on 4:40 pm on Sep. 8, 2003[br]A. Don't go 145. :-)
LOLI agree, going 145 is way to slow for a ZR-1. It got pissed off for not being allowed to stretch it's legs around 180 on that open road, so it threw the sensor. Next time, don't hold her back, and she will not react so poorly.
Old 12-15-2003   #8
Anonymous
Default
the owners manual ses u can cancel this option thrue the dealer any idears
Old 12-15-2003   #9
Anonymous
Default
When I throw on new tires this spring I'm going to take off the sensors and take out the bulb.
Old 12-15-2003   #10
Anonymous
Default
Quote: from Dandy97 on 8:19 pm on Nov. 29, 2003[br]When I throw on new tires this spring I'm going to take off the sensors and take out the bulb.
Good idea Dandy97 most of us do it that way.
