Old 09-12-2008   #1
Shinto
Shinto's Avatar
Default Experiencing electrical failure
Last night I was on my way home and the "Service ABS" light came on followed a minute later by another about the SRS, then the SES light a few seconds later. I raced into the nearest parking lot and shut down. It wouldn't restart. I had to have my wife come out with the jumper cables and jump start it. It ran fine for about 2 miles and everything started happening again, this time I lost my headlights and dash lights and the engine began cutting out before shutting it down and jumping it again for a good 20 minutes. I started the car and ran as fast as I could and got it about a block from home before everything went dead shortly before the engine died and I had to bring to the side of the road dead stick. (Ironically I went right past a Sheriff's deputy at 45 mph in a 25 with no lights on to save power and he didn't seem to care...)
Strangely, the battery light never came on.
I highly suspect the alternator is dead and the engine was running off the battery until it ran out of juice. Anyone else experience this? Any other alternatives? Somehow, I'm not convinced its the ECM.
Also, I saw either here or another forum some time ago where someone came up with a method of swapping in a much cheaper L-98 or LT-1 alternator. Can someone point me in the right direction here?
1991 ZR-1 #1926 Black/Black, Borla Exhaust w/ X-pipe
Shinto is offline   Reply With Quote
Old 09-12-2008   #2
Shinto
Shinto's Avatar
Default Re: Experiencing electrical failure
Just a quick follow up -- After charging the battery for a few hours now, voltage at the battery terminals is 12.27V with the engine running and 12.54V with the engine off. This seems to confirm my suspicion that the alternator isn't working and the engine is running off the battery. So how do you get to the alternator?
Old 09-12-2008   #3
tccrab
tccrab's Avatar
Looks like you've got a plenum pull in your immediate future.
I've got extra gaskets & the right tools.
I'm up in Folsom, drop me a call if you'd like some help.
TomC
'90ZR1 #792
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 09-12-2008   #4
Well im not sure about a plenum pull but I do know the Air cleaner unit and Air Horn and S-belt need to be removed. Are you sure TC I defer to you since I have never done the alternator job before but I sure gave that area a good look a couple of weeks ago when I did the Water pump
Old 09-12-2008   #5
Sgreg
Sgreg's Avatar
Can be done without a plenum pull. Goldcylon has the right idea.
1991 ZR-1, Black, Black, # 541
Sgreg is offline   Reply With Quote
Old 09-12-2008   #6
Greg batten down the hatches bro its looking bad!!!!!!! Tell Ike to go Away Tinas not home !!!
Old 09-12-2008   #7
tccrab
tccrab's Avatar
Thanks guys, good information.
Saves lots of time.
I wasn't sure if the plenum had to come off or not. It didn't look like there was enough room to wiggle it out from under there without lifting off the plenum. It's been a couple of years since I've been under the plenum (thank gosh).
TomC
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 09-12-2008   #8
Sgreg
Sgreg's Avatar
Yeah, I figure I will lose the power in the hacienda any minute now. Starting to blow pretty good. Adios !!
Old 09-12-2008   #9
tf95ZR1
tf95ZR1's Avatar
Whenever my SES light has gone on it was (just) the battery.
Removing the alternator is a lot of work however you get access to it.
Is there any way to test the alternator on the car? ie test it
under load?
I would do that first.
My $0.02
Good luck,
Ted
Oops, big FU. It was when my SYS light goes on, not SES. Sorry.
How do I know? My SYS just lit up, had to charge battery.
Old 09-13-2008   #10
Pete
Pete's Avatar
If your only getting 12.2 volts with it running sounds like the alternator.
Myrray's Auto Parts
Autolite #A145761 $112 + $18 core
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
