Old 08-31-2008   #71
karterdon
karterdon's Avatar
Default Re: Fuel Injectors
If any of you need O-rings - I have them - $1.50 / O-ring. I did a lot of research - They are Vitone rubber and are resistant to all of the bad things that make them go bad and have a fantastic temp. range. I learned my lesson when I tried to by them from GM and Kurt white - Kurt wanted $16.00 per oring and my local GM dealer wanted $20.00 - He was only able to find -(1). So I went looking on my own - did not want to let KW take unfair advantage of me. So if you are interested let me know - They are easy to drop in the US. MAil - You will need a Qty of 8.
Just PM or send me an e- mail
Karterdon@aol.com
Don Yoakem
91-#267 Dark Red Met.
karterdon is offline   Reply With Quote
Old 09-01-2008   #72
Karterdon@aol.com
Don Yoakem
I'm using a set I bought from Don. They are excellent!
Old 09-04-2008   #73
billybaloneey
billybaloneey's Avatar
I have read all eight pages of the fuel injector topic and did not see the answers to my questions:
1) What are the ratings for a '94...21#?, 22#?, 24#????
2) Are the primary and secondary ratings the the same?
3) If I go with the Accel's...mentioned in the posts...would I need the O-rings mentioned in the post?
Thanks
Clint aka billybaloneey
'94 - C4 ZR-1 #445 - Black/Black
'05 - C6 silver/black 6sp
'85 - C4 white/graphite (almost done) automatic
'78 - C3 silver/black (a work in progress) automatic
billybaloneey is offline   Reply With Quote
Old 09-04-2008   #74
Jeffvette
19lbs
Yes
No
Old 09-05-2008   #75
billybaloneey
I visited one of the suggested sources for fuel injectors...Atlantic Speed.com and the only LT5/ZR-1 injectors they list are 21#'s. They show the 19#'s for use on '93-97 LT-1's.
Are there any advantages or disadvantages using a 21# (Accel) instead of the recommended 19#'er?
Old 09-05-2008   #76
Jagdpanzer
Jagdpanzer's Avatar
BB,
I ordered sixteen of the #21's from Atlantic Speed for my 94 Z.
Old 09-05-2008   #77
Aurora40
Aurora40's Avatar
Originally Posted by Jagdpanzer
BB,
Have yours failed? I didn't think the '93+ injectors tended to have issues?
Bob Saveland
Former owner of #2517
Old 09-05-2008   #78
Jeffvette
They have less issues, but will still fail from lack of use.
Old 09-05-2008   #79
Jeffvette
You are supposed to use the 21lb for the LT5. If you use the 19lb accels you will lean out the motor.
Order Accel 150821 cut off the alignment tab and remove the lower o-ring on the injecotr body for the primaries and install.
Old 09-05-2008   #80
Jagdpanzer
Jagdpanzer's Avatar
No failures yet, I'm a diesel man and you can't sleep easy unless you have a spare set of injectors handy just in case you run into some bad luck.
Plan to put them in this winter along with the P&P plenum and IHs.
