Old 08-31-2008   #31
Default Re: The dreaded water pump failure and a weekend project
Originally Posted by tomtom72
Hey Daryl glad to hear that all is okay! Nice job dude!
You are aware of the GM reason for using the "sprung steel band clamps"? They were getting complaints about 'coolant smell' from Z owners. The 'smell' was after the motor went thru a heat cycle, and upon cool down after engine shut off the smell was fairly strong. No liquid leaks, but a ton of small vapor leaks. The 'ideal' type screw clamps were not expanding and contracting with the aluminium parts and allowing vapor to escape....their answer to this was to use those "clamps from he!!".
I'd be curious to know how the real Samco clamps perform with regards to this issue. Yea, I used ideal clamps and mine leaks vapor on cool down...we didn't have the samco clamps when I bought my hoses.
Good luck with the new stuff!
Tom I remembered your post up about that issue earlier. In fact I remember you went back somewhere to try and recover the clamps. After the problems with the clamps this was the best solution for me. These clamps look identical to the ideal clamps but are stainless. they track smooth while turning and are tight. After I go through a few heat cycles I will let you know. Phil just stated he had the Samco preferred hose clamps and he can smell the glycol.
Old 08-31-2008   #32
Originally Posted by -=Jeff=-
Thanks GC!! I will check it out
If you cant find it let me know. My son works for Checker maybe I can get a Forum buy together lol. But before that happens somebody has to post up what the real GM tool looks like because I want to see the differnce. My little tool is not exact but gets the job done.
I should have my car all together tonight. I will post up the pics of the install and the tool for everyone to take a gander at. GC
Old 08-31-2008   #33
Originally Posted by cuisinartvette
Shot some of those clamps across the garage like a cannon, lucky I didnt lose an eye.
No **** bro, or break a finger or injure a small animal
Old 08-31-2008   #34
rhipsher
rhipsher's Avatar
I don't know man! Squirrels are pretty tough. I hit one friday at 50mph. I heard 5 thumps hit the floor board. I looked in my rear view mirror and saw him run right up a tree. I couldn't believe it.
Old 08-31-2008   #35
Drive around those armadillo's though!! Man, they're like hitting a rock!
Old 08-31-2008   #36
flyin ryan
flyin ryan's Avatar
The moose up here do serious damage to 18 wheelers, forget about passenger vehicles , it can get real ugly when Bruce the Moose decides he wants to cross the road .
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y.
Old 08-31-2008   #37
I have Murrays, Advance and Autozone, as well as Napa and Carquest
if none have it I will let you know
Old 08-31-2008   #38
Heres a picture of the Corban clamp removers
Old 08-31-2008   #39
Ok completed.
You need to cut the rad shroud in order to get the shroud out. Its the only way unless you pull the AC lines and Oil Cooler lines. Dont worry I cleaned it after the install !
All together !
New Radiator
Old 08-31-2008   #40
I cut my shroud the same way when I did it too, but mine is coming back apart this winter to swap in the bottom breather air box
