Old 06-24-2008   #1
32valvZ
32valvZ's Avatar
Default A/C compressor seal
anyone know where to buy one? Looking for the front seal for my 93 Ruby (non ZR-1), but I think the compressors are the same. Any special tools needed?
Old 06-24-2008   #2
Default Re: A/C compressor seal
Don't know about the tools but try Rock Auto for the Seals
Old 06-24-2008   #3
QB93Z
QB93Z's Avatar
I don't know about seals, but the compressor for an LT5 is not the same as for an LT1. I am preparing to replace the AC Compressor in my '93Z.
Old 06-24-2008   #4
What is different? looking at mine whe it was apart, aside formt eh outlet/inlet lines being different, the compressor itself looks to be the same Nippondenso unit on my 89. although I might need to look again
Old 06-24-2008   #5
WVZR-1
John,
If you're talking about the shaft seal on the Nippo it's actually behind the cylinder head and only the "felt" forward of the cylnder head was serviced seperately.
I can send you an image of the compressor disassembled if your interested. You will need an image viewer for the GM catalog that I'll send you information on. Should run on your "MAC"!
The shaft seal on the backside was available as part of a master gasket set for quite a number of years but is "no longer"! I've never tried to buy the shaft seal but I believe I could. I've done some unusual AC on armored vehicles with odd refrigeration systems! Patience!
I've got your e-mail!
I get in generally around 7:15 in the evening!
-Dave
Old 06-24-2008   #6
32valvZ
32valvZ's Avatar
Ok Dave, that would be great. The front of the compressor is slinging oil on the underside of the hood. After getting a few opinions, I think it needs whatever seal is in the front of the compressor. It still blowing cold air though as of now
