05-25-2008 | #21 | |
Re: euro taillights install
If that was the case thats the option I would use as notbody really wants to splice into their harness unless they have too..
05-25-2008 | #22 | |
05-25-2008 | #23 | |
05-25-2008 | #24 |
Jeff maybe Ebay???? Might be worth the $10 to start? 290202401799
05-26-2008 | #25 | |
05-26-2008 | #26 |
here's the instrustions that come with the Eckler's wiring harness
http://www.ecklers.com/assets/pdf/40372.pdf? and here is page for the harness it's self http://www.ecklers.com/product.asp?p...2&dept_id=1499 Eckler's harness is not a plug-in and you'll have to cut or unplug the white wire in underdash modification. This is so the hazard lamps flash thru the amber lamps now instead of the red lamps. I made my wiring harness and have far less than that price. Also with doing the conversion on a ZR-1 you have to tie into the high level stoplight and to do this you have to tie into that harness in the halo(passenger side) or do what I did and tap into the brake applied input on the EBTCM(electronic brake and traction control module) behind the driver's seat. |
