#21 | |
![]() Join Date: Jul 2007
no o2 Ground is its own ground..
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
#22 | |
![]() Join Date: Jul 2005
Yes, a code did come up. I was at Doug Rippie's place when the code occured. Doug did not give me a code # but said it was the cam sensor fault.
Bob Anderson 1990 #2405 White/Gray Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported Minnesota State Director Founding Member #19 |
#23 |
Jeff,
Have you thought of looking at the ECM grounds? Odd that O2 sensor ground would be bad. ![]() |
#24 | |
One step at a time.. going to check this fix this weekend. see if I got anywhere. then move on to the next issue
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 Last edited by -=Jeff=-; 05-23-2008 at 10:13 AM. |
#25 | |
#26 | |
#27 | ||
Again, from what I read in the Service manual they seem to be fine.
#28 | |
#29 |
Update..
Injectors are FINE, Coils FINE.. I am working out a coupe things and don't want to speak too soon, but I thank I might almost have the issue resolved
#30 |
I'm on pins and needles!
