Old 09-10-2005   #21
Mika73
Default
There is broken intake cam on my engine..
Could someone help, please..
(Haibeck sells 4 cams set 4000USD)
Mika73 is offline   Reply With Quote
Old 09-10-2005   #22
wdo-mkr
Thumbs up
Lets hope they are at least aftermarkets with a larger lope. Good grief. It looks likek you have another cam coming from lotus(cliff) on the other forum. Keep in mind that you should replace the lifters as well under the cam that has broken. Here is a link for you to give you another option for cams. Hang in there.
http://www.lt5-parts.com/library/cat...5%2C%7CTop+End
If either of those deals fall through, I have a set of stock cams sitting on the shelf with only 30k miles on them as well.
wdo-mkr is offline   Reply With Quote
Old 09-10-2005   #23
Mika73
Default
Thanks
Yes. Cliff did send me cam. It leaves from UK to Finland at monday.
Lingenfelter also had cams.
Old 09-24-2005   #24
Z Factor
Z Factor's Avatar
Default
So did you ever get an answer as to what the probable cause to this mess was? How are things coming along?
Old 09-26-2005   #25
yellowz
Default wont run
hey mika
i no u said you swapped the coil positions but the gm # is the same for all 4 ib be willing to bet that you have a bad coil why not replace the one thats bad???
i would think if it were bad at 2,7 then you swapped it at another position it would do the same there???.2 years ag at carlise i had a canadien zr1 and his owner come done to fix a problem he had many issues bad tensioner,2ndary vac pump leak and it would run but you could feelit running on 6cylinders after gordon recheck the problem it was a bad coil,his was missing and not firing after we put the coil in took it for a blast up i81 the kid was all excited and thrilled.
I still think you have an electrical issue ,if you replace the coil while you are there although expensive replace the coil module.
yellowz is offline   Reply With Quote
Old 10-13-2005   #26
Z Factor
Z Factor's Avatar
Default Re: LT5 wont run with all cylinders
Any updates?
Old 11-19-2005   #27
Mika73
Car is running now. Thanks to Haibeck of all help
Old 11-19-2005   #28
Aurora40
Aurora40's Avatar
Cool! So what was the problem?
Bob Saveland
Former owner of #2517
Old 11-19-2005   #29
cuisinartvette
fwiw, www.nelsonracingengine.com can get cams made to any lobe and hardness. I belive they are $2500/4. May want to contact him for specific info.
1990 ZR1, 142,000 miles-Black on black
4.09's Haibeck chip, 3"exh, K&N, meth inj.
Old 11-21-2005   #30
Mika73
This..
http://forums.corvetteforum.com/phot...05_112-med.jpg
