Old 05-18-2008   #1
Default My tuning issues
Just like =Jeff=, I decided to do a scan on my motor the other day trying to tweak and optimize tthe tune now that I'm back from BG. Prior to going, BLMs were in the 124-132 range depending. Idle was fine.
But with the latest scans, idle BLM is sitting at 115 both sides and INT is at 100. ECM is adding fuel although I have taken fuel out of the VE tables.
Motor transitions smoothly from Open to Closed loop. Idles at 725-750rpm.
And it doesn't smell rich once warmed up. Idle injector PW seems a bit high at 4ms. As I said in a previous post, Left side 02 appears a bit lazier than right but they track pretty closely to each other. No codes although I did have a VAL 66 which is a shorted or shunted VALET switch code. However as of last scan, that did not appear.
I'm thinking some kind of exhaust leak particulalrly given that the low BLMs are in the lower MAP region where vacuum is high and would suck in fresh air. That would explain why motor runs better than scan would indicate. Whatever it is appears to affect both sides equally and I am not sure where an exhaust leak could happen which would affect both sides.
Old 05-19-2008   #2
Default Re: My tuning issues
Something else I noticed today is that it did take a while for the motor to go into Closed Loop. Coolant Temp got high enough for fans to come on but still no C/L. Once in C/L, BLM and INT started to fall.
Old 05-19-2008   #3
bradslt5
could thatr mean the main computor is starting to go away .here one for ya . was cruizing along at 85 when allof a sudden the speedo went to 59 and the ave fuel went fro 25.1 to 20.0 this lasted fro about 3 min it,magiclychange to what it was reading before
Old 05-19-2008   #4
Brad,
I don't think that's it. Its been pretty consistent with the last several scans. Right now I'm investigating a leak at the header collector. The motor doesn't surge, its idling nicely, so that tells me whatever is causing the ECM to see a lean condition is coming after the intake side. Its not turning on/off like a light switch.
Old 05-19-2008   #5
Got it. Bad bin file. I'll need to retrace my steps and see where it went wrong. I was able to pick a bin I knew had worked and downloaded to the Ostrich. Bingo! BLMs and INT in line. Now I'll transfer my other changes to this bin and move on. Time to scan again.
Old 05-19-2008   #6
Great to hear, do you think was effecting your BG runs?
92 ZR1
#234
LGAFF is online now   Reply With Quote
Old 05-20-2008   #7
bradslt5
cool , glad ya found it . never did here how she ran @Bg?????
Old 05-20-2008   #8
bradslt5
coing to try to take the snat to the strip this fri and see how she does .can hardly wait
Old 05-20-2008   #9
Brad,
Best time there was a 12.8@ 115.5. 60' was a pitiful 2.3.
Old 05-21-2008   #10
bradslt5
it gets really hard to launch the car on street tires after porting .well now ya need mt et street drag radials . ps i finally found those dyno sheets i will copy them and put them in the mail to ya unless ya have a fax number . have a great memorial weekend . fri a buddy and i are going to take both myzr1 to the strip for some fun. gotta tryout new rear suspension mods and bill great trannies too
