Go Back   ZR-1 Net Registry Forums > Off Topic > Review/Evaluation
Old 09-07-2005   #11
Nick
Default
Yes, the ceiling is 10 feet high, but the door takes up almost two feet of that in the open position. Solution: I've moved the door stopper to stop the door before it hits the back window of the '55 Chevy. Its a bit of exercise if I want to take the boat out, as its windshield is taller than the opening in the door, but it works, and all the toys are tucked away in the garage.
Nick
ZR-1 Net Registry Founding Member #32 - lapsed...
Old 09-28-2005   #12
TommyL
Lightbulb Re: Home Car Lifts
Nick, You should run your door strait up the wall then curve to meet the celing that would be the perfect solution.
TommyL is offline   Reply With Quote
Old 12-22-2005   #13
Nick
Default Re: Home Car Lifts
Yes, need to do that this Summer (or sooner, I'm getting bored )
Nick
Old 12-22-2005   #14
yellowz
if you call Carl Zander in florida he still may have the couble park 2 which mom and a few of us have.his number is 1-440-871-6496
later
peter
yellowz is offline   Reply With Quote
Old 02-01-2006   #15
ZR1 MK
I have the Cytech 4 post for many years. So far, the only issue is the bronze bushings. They arent as durable as I feel they should be and they are deteriorating. Replacement is a hassle. I was told by the manufacturer, I must buy the pulleys too or go locally for the bushings. Anyone replace their bushings?
Mike
427 cu in LT5
[URL="http://zr1mk.weebly.com"]http://zr1mk.weebly.com[/URL]
ZR1 MK is offline   Reply With Quote
Old 06-04-2006   #16
BBBAD94ZR1
BBBAD94ZR1's Avatar
You need to get off the pipe Margaret..
[FONT=Century Gothic][SIZE=5][COLOR=black][I]:dancing[/I][/COLOR][/SIZE][/FONT]
BBBAD94ZR1 is offline   Reply With Quote
Old 11-14-2012   #17
I thought this thread needed an update. After much research, this past summer I bought a Direct Lift Pro Park 8S for my 21'x21' two car garage with an 18' door. I have posted quite a few pictures in my Album section--just click on my avatar. I paid $2,100 for it plus another $900 for shipping and installation and a 90 degree bracket to move the motor parallel to the ramps instead on the side (as a result I now have about 24 inches from the wall to the post an can get out of my car and get by it with no problem.) My ceiling is between 9'8" and 10'. I raised the garage door tracks to within 6 inches of the ceiling (and later cut off a section of the door top brace to be able to bring my BMW in forward--the satellite radio antenna was hitting.) Also installed a jackshaft opener which I really like-- a Liftmaster 3800 and it is quiet. I ran surface mounted conduit from the old opener's duplex for outlets for the opener and the lift motor/charger. I have swapped cars several times a week for most of the time since installation and it works fine. 10 minutes max to swap cars. Anyone in the Chicago area is welcome to come see it. – Bob
