Old 04-20-2008   #1
Ccmano
Ccmano's Avatar
Default Reading Coolant Temp on the ACC Panel..
Can someone remind me how to switch the ACC display so it reads engine coolant temp instead of ambient air.... I can't find a link anywhere on how to do it and I know it's just pushing the buttons in a certain sequence.
Thanks
Hans
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 04-20-2008   #2
Bill
Bill's Avatar
Default Re: Reading Coolant Temp on the ACC Panel..
Press and hold both fan up and down arrows for about 5 seconds (until “00” ) appears in the display. Use either fan up or down to scroll to “16” then press fan “auto”. Coolant temp will then be displayed in degrees C.
[img]http://home.comcast.net/%7Ebsoomann/srsig.jpg[/img]
Bill is offline   Reply With Quote
Old 04-20-2008   #3
Ccmano
Ccmano's Avatar
Thanks!!!
Hans
Old 04-20-2008   #4
QB93Z
QB93Z's Avatar
That's pretty cool. Is there a write up somewhere of all the parameters that can be displayed?
Old 04-23-2008   #5
I second that. Had no idea this was possible. On a 90? or 91?
Old 04-23-2008   #6
Jeffvette
It's in the manual
00 - System faults
01 - Temp setting in degrees
02 - In car temp sensor
03 - outside ambient air temp
04 - Sun load sensor
05 - Ignition system voltage
06 - Engine speed /25
07 - Vehicle speed
09 - System mode
10 - Blower pulse width modulation
11 - Program number
12 - Mix number
16 - Engine coolant temp Cent
30 - Stored full hot value
31 - Temp door travel range
34 - Temp door feedback
35 - Compressor on time (in seconds)
36 - Number of times below critical time
37 - Software version number
Old 04-23-2008   #7
QB93Z
QB93Z's Avatar
Thanks Jeff.
Old 04-23-2008   #8
Originally Posted by Jeffvette
It's in the manual
00 - System faults
07 - Vehicle speed
09 - System mode
11 - Program number
12 - Mix number
Must of missed that page? Thanks Jeff
Old 04-23-2008   #9
White Bullet
White Bullet's Avatar
Outstanding! Thanks.
1991 ZR1, White/Red.
White Bullet is offline   Reply With Quote
