Old 04-08-2008   #1
lbszr
lbszr's Avatar
Default Had to try it
Took the B@B resonator off and put in two straight pipes. Had some 3inch pipe so didn't actually cost anything but a lot of work. Also with headers.
All I got to say is Wow, think I've lost some hearing after a two hour drive, resonance didn't seem that bad at the time but it must of caught up with me. Above 2 grand it's not bad though. Just can't cruise.
Guess I'll try the X pipe now but sounds like there's complants out there on that setup also so might be wasting my time again. The resonator chocks down so much can't bring myself to put it back on though.
Old 04-08-2008   #2
Default Re: Had to try it
LOL well dont take this the wrong way but "duh" lol. Must have been pretty brutal
Old 04-08-2008   #3
try a Xpipe with a pair of Magnaflow Bullet mufflers..
removing the Resonator and replacing with straight pipes or a Xpipe will be louder.. since there is less to muffle the sound
Old 04-09-2008   #4
lbszr
lbszr's Avatar
I'll try the xpipe and does the Magnaflow bullet's have a comparable sound outside the car to the B@B's?
Kinda like the B's sound, actually sounds really good now with resonator removed and not much louder on the outside.
Old 04-09-2008   #5
lbszr
lbszr's Avatar
Girlfriend verified it was pretty brutal on just a 10 mile trip.
Old 04-09-2008   #6
You I just realized i should expand my previous comments.. run the Xpipe, sfter the X pipe ( before the bends) run a pair of Magnaflow bullets.. then run the B&B Mufflers.. it gives a non neck down solution and the Bullets muffle the sound like the resonator did
Old 04-09-2008   #7
lbszr
lbszr's Avatar
Just looked the bullets up at jegs and that would of looked kind of strange in the back, I'm likin the sounds of this setup, thanks for straightening me out!
Old 04-09-2008   #8
Old 04-10-2008   #9
Demps
Demps's Avatar
I have gone back and forth between the x-pipe and resonator (haven't done the pipes) and the x-pipe is brutal on noise. I'll take the x-pipe every time though for the power addition. I don't drive mine cars as a daily driver but for pleasure.
Old 04-10-2008   #10
What say Sonny ?
