1 Week Ago | #11 | |
Re: Dreaded no start
And I do NOT want to get into habit of a vehicle starting when in gear with the clutch switch installed and working.... And me popping the clutch and having 400 horses jumping forward or junping backward 😁😁 I assume the ZR1 will start in gear with clutch depressed....I will confirm that in a few minutes YES....My ZR1s will start in gear with clutch depressed .... so.....what happens if my foot slips off the clutch with engine running and transmission in gear Nothing will happen with my habit of always taking a vehicle out of gear before starting the engine (and I want to let the engine warm up a bit before putting in gear to make sure oil iis fully circulated)....... I operate way too many vehicles not having a Clutch safety swiitch making it a habit to take vehicle out of gear when starting (starting your ZR1 in gear may not be so safe as you might think) I may be all wet but it would not be the first time
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 1 Week Ago at 01:38 AM. |
1 Week Ago | #12 |
Remember.......you can always push start a ZR1 in second gear.....two guys can easily push a ZR1 on relatively level ground.....
Just get the ZR1 moving forward a bit (clutch depressed and key on) and pop the clutch in gear This is the only time I start a ZR1 in gear A No Start is no longer "Dreaded" as you might think Also.....Remember a simple jump start will often provide enough additional voltage to increase the field strength of the starter solenoid to move a sticky solenoid.....or increase the voltage for higher resistant solenoid contact points iincreasing the field strength of the starter windings itself 👍 That is why we always ask "do you here a click when you turn the key on" a no start..... "No Click?" (the issue is low battery or sticky starter solenoid)..... "You hear a Click"....(the issue is the starter solenoid contact points or the starter itself).....
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 6 Days Ago at 09:31 PM. |
