Old 06-18-2024   #1
scorp508
Question How many gallons of gas when at "reserve" marker?
In my '94 I'm noticing when the fuel gauge reaches reserve, I am only able to get about 13.5 gallons of fuel into the tank. What are others seeing? My '87 with the same size tank usually accepts around 18 gallons, give or take, when it hits reserve at something like 50 miles of range to go. Unfortunately, I'm trying to fix a flashing SYS on my 94 central dash display, so I don't have access to the digital range at this time.
I've read Marc's article on heavyweight Z's, but it sounds like the issue was fixed in late '93 and subsequent cars should be able to use the whole tank.
http://www.zr1specialist.com/HAT%20W...0discovery.pdf
1987: Z51 Coupe, Z51, 4+3, Yellow / Graphite, 310 RWHP 350ck L98
1994: ZR-1 #150, Admiral Blue / Black, 445 RWHP 350ci LT5
2015: Z06 Coupe, Z07, M7, Arctic White / Red, Stock LT4
scorp508 is offline   Reply With Quote
Old 06-18-2024   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: How many gallons of gas when at "reserve" marker?
Had a similar problem with my 94.
Solved it by pulling the sender/pump unit and enlarged the vent hole on the side of the fill pipe to 1/2". Now it fills to 18+ gallons at the gas pump without having to spoon feed the last gallon or two.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 06-18-2024   #3
ghlkal
ghlkal's Avatar
At reserve, I can put in 17 gallons.
FWIW ... I replaced my sending unit a few years back. The new one is "non-linear" - it will show Full for a long time, and then it goes through the middle of the range "faster," but it slows down near the bottom of the scale.
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
Old 07-26-2024   #4
scorp508
For what it is worth I have my sending unit out due to a failed primary pump and it does not have the rubber hose on the inlet like the "heavyweight" cars Haibeck documented. I think I'll drill out the vent hole like you did and see how it goes.
Just to be clear, you are referencing this little pinhole?
Old 07-28-2024   #5
Erik
Attachment 20618
What are the ?heavyweight? cars?
1990 ZR-1 # 996
Old 07-28-2024   #6
scorp508
http://www.zr1specialist.com/HAT%20W...0discovery.htm
Old 07-28-2024   #7
Erik
Awesome!
Thanks.
1990 ZR-1 # 996
Old 07-31-2024   #8
Mr.Yuck
Hit reserve, I put in 16.5 gallons.
Mr.Yuck is offline   Reply With Quote
Old 08-15-2024   #9
scorp508
Thumbs up Re: How many gallons of gas when at "reserve" marker?
I drilled mine out to ~3/8" when I had the sender out to swap fuel pumps. I haven't driven it enough to get to reserve and see if I'm now able to get more than 13.5 gallons in, but I did top it off and she filled nice and fast right to the top.
Old 08-26-2024   #10
scorp508
With Phil's tip I am now able to put in ~16 gallons when I hit reserve.
