04-17-2024 | #1 |
starter rebuild kit
Is there a kit available that would let me rebuild a starter myself? Or a list of parts needed?
New starter is already in the car. I can send in the old one for a core refund, or try to learn from it. I'd rather try to learn if possible. |
04-17-2024 | #2 |
Re: starter rebuild kit
Right in Wazoo's hands. Come on Saturday for maintenance day and Dan can show you what he did with mine. I believe we have several rebuild kits at Jim's.
04-17-2024 | #3 |
The solenoid plunger I have never located new the contacts are available
04-24-2024 | #4 |
Charlie, can any of you wazoo guys bring a set to the MR / gathering?
I urgently need one and that's my ultimate chance to get it... Thanks!
ZR-1 #638/1991 |
04-24-2024 | #5 |
Hi Matt, unfortunately I will not be able to attend this year but will check for you.
04-25-2024 | #6 |
Matt, sent you a PM.
06-10-2024 | #7 |
Hey guys. I need to rebuild my solenoid as well.
From my research, I see that I need the Denso 053660-7061 plunger kit, which comes with contacts and a plunger. Will I need anything else? Is there a how-to write-up I can reference? Last edited by anton28; 06-10-2024 at 10:52 PM. |
07-06-2024 | #8 |
Well, I was able to purchase the Denso 053660-7061 plunger kit and just went to purchase another one for a second starter, but I'm told it has been discontinued, and I can't find it anywhere online.
Does anyone have a lead on one? |
3 Weeks Ago | #9 |
Did you ever find one?
1995 ZR1 #159 Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp 1992 ZR1 #280 Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp 1996 Collectors LT4 (Stock) 1972 Convertible 434 Small Block 572 rwhp |
2 Weeks Ago | #10 |
File the contacts to remove carbon deposits. I even use a die grinder stone on my battery drill to shine them up. The starters seem to require it at 30-40k miles of use.
