Old 03-29-2024   #1
Mikey
Default Seatbelt retractor issue
My retractor locks during driving when the car hits a bump that is jarring enough or during spirited driving. Then it won't release and the belt continually gets a little tighter each time it happens to click another notch retracted. I have to unbuckle and let it retract fully so I can pull it back out.
Mine is a 1991. I thought I read that the retractors had an improved design in later years. Can anyone confirm what part is recommended to replace it or some other fix?
Old 03-30-2024   #2
tf95ZR1
tf95ZR1's Avatar
Default Re: Seatbelt retractor issue
https://www.zr1.net/forum/showthread...eatbelt+recall
1995 ZR-1 #106 Blk/ Blk
Owned by me since 2000.
93K miles, but not on motor :-)
Mods the way I want it,
Not afraid to drive it!
Old 03-31-2024   #3
Mikey
Originally Posted by tf95ZR1 View Post
That recall says that the retractor locks up preventing the user from deploying it. This is not the same issue I?m experiencing. Mine always deploy. But then they get a bit overzealous and lock and ratchet tighter until I release, fully retract and redeploy.
Old 03-31-2024   #4
I believe that to be the correct functionality for the seat belts..
Old 03-31-2024   #5
Mikey
It?s definitely not. It should unlock itself after a period of smooth uneventful driving. It should not just keep working itself tighter and tighter during regular driving.
Old 03-31-2024   #6
Back in 1993 when I had my 89, I had the SAME thought, took the car to the dealer and was told that was the expected behavior. My 89, 90 and all the other C4s I have driven, all the same
Old 03-31-2024   #7
Mikey
I can assure you it?s not normal or else the design was improved in later C4. I have never owned any other car that behaved this way. And my 1994 C4 didn?t have this issue. Maybe I will just buy later year retractors.
Old 03-31-2024   #8
The 1994 retractors I have will cinch the lap belt on their own after spirited driving. The shoulder belts do lock then release but the lap belts have always done this.. I have another set of belts from a 94-96
I can try but as far as I know the lap belts always worked that way
