Old 09-21-2023   #1
DaveK
Default Cleaning under plenum
Hi everyone,
I've removed the plenum to switch out the starter motor and there's a lot of thick black grime underneath. Any suggestions for the best way of cleaning there?
Also, this plastic clip crumbled when I moved one of the lines. Are they available anywhere?
Thanks
Dave
1991 #1516 Black/Black
davidmkelly.com
Old 09-21-2023   #2
Default Re: Cleaning under plenum
I use mineral spirit, a toothbrush and a lot of rags. Once cleaned, fresh injector housing gasket and positive seal at PVC hoses should keep it reasonably clean.
Old 09-22-2023   #3
DaveK
Thanks, I'll try that
davidmkelly.com
Old 10-08-2023   #4
Young1
Young1's Avatar
Put duct tape over intake ports to prevent anything falling in there. Don?t have an oops.
Steve Young
Second Owner
SOLD
SOLD
Old 10-10-2023   #5
DaveK
Thanks, Steve. I did that a couple of minutes after taking the photo
davidmkelly.com
Old 10-10-2023   #6
I'd suggest if you're not in a hurry to get it back together pull everything out off,clean and put it back together.
