Old 04-05-2023   #1
Subfixer
Subfixer's Avatar
Default Secondary fuel pump dead?
Car runs fine, except when at full throttle going through the gears. Then acts like fuel shutoff. For short bursts of full throttle, everything is ok. I'm thinking the secondary pump isn't keeping up, or only the primary is working.
Sent from my Pixel 4a (5G) using ZR-1 Net Registry mobile app
1992 ZR1 #442, 2 tops, White, White, Haibeck 415, 3.90 gear, Coilovers
2018 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black
2021 Audi Q3, 2.0T, 8 spd Tiptronic, Navarro Blue metallic, Pearl Beige
Subfixer is offline   Reply With Quote
Old 04-05-2023   #2
Young1
Young1's Avatar
Default Re: Secondary fuel pump dead?
Most likely yes. To confirm perform the fuel pumps amperage test on the red pigtail at the wiper motor. Your meter will read 7-9 amps if both are running. 3-4 amps if one is running. Details in the Stickies.
Steve Young
Second Owner
SOLD
SOLD
Old 04-08-2023   #3
Do you still have the Secondary Port Throttle (SPT) system still in place?
If so, test the vacuum pump and each of the vacuum actuators. A failure of any 1 of those 3 items can cause the same symptom.
Old 04-08-2023   #4
Subfixer
Subfixer's Avatar
Secondary Port Throttle (SPT) system is still in place. Entire system was checked by Marc when my 415 was built less than a year ago. Vacuum pump doesn't cycle at all. Pretty sure its a pump. Will be replacing both today.
Old 04-08-2023   #5
Subfixer
Subfixer's Avatar
My first check was the current draw. Current reads 9.3 Amps, so it seems both pumps are running.
Next check will be fuel pressure.
Old 04-08-2023   #6
Subfixer
Subfixer's Avatar
Fuel pressure check.... not good.
Only 42psi at cold idle.
Old 04-08-2023   #7
Subfixer
Subfixer's Avatar
I really am disappointed in aftermarket Chinese parts.
After replacing both pumps with Delphi FE0039 units, I now have a combined fuel pressure of 20psi.....
Old 04-08-2023   #8
If the vacuum pump doesn't cycle at all, how do you know if it is still working?
Old 04-08-2023   #9
Subfixer
Subfixer's Avatar
Vacuum pump does cycle, just not excessively. About once every 45 seconds after initial pump up.
Put old (original) fuel pumps back in for now.
After removing and replacing the assembly 3 times, I'm now an "expert".
Old 04-08-2023   #10
Subfixer
Subfixer's Avatar
Any recommendations for "good" fuel pumps?
