Old 01-30-2023   #1
Azrael
Default Dymags in 17x11
Hey, I'm looking at an 88 vert that has Dymags in ZR-1 sizes, were there any 17x11 Dymags with an offset that isn't correct for a 90 ZR-1? I don't want to fly out to buy this car for the wheels then get home to them being the wrong offset if the seller doesn't know the specs
Azrael is offline   Reply With Quote
Old 01-30-2023   #2
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Default Re: Dymags in 17x11
A concentric spacer and longer studs are required for proper fitment.
I am not aware of multiple offsets.
Marty
Old 01-30-2023   #3
Azrael
Interesting, so the 11" Dymags are offset for the base cars?
Old 01-30-2023   #4
Challenge Style 17x11 Dymags have the correct offset for a 90 ZR-1. The 17x11s in the later style wheels is 56mm... you need a spacer. 1988 has a 56mm offset
Old 01-30-2023   #5
Azrael
What's the best way to tell visually? They do appear to stick out a little on the rear but it's hard to tell from the pics.
File Type: jpg 306976501_4172496196308247_6057524206466837917_n.jpg (96.0 KB, 61 views)
Old 01-31-2023   #6
DRM500RUBYZR-1
Those are gen 1 challenge Dymags.
Disregard my answer as it was for Gen II wheels.
Marty
Old 02-01-2023   #7
The tires on the rear look to be too wide for the wheel.
Old 02-01-2023   #8
Azrael
Hard to tell from the pics, but that's a good point, I hadn't considered someone would be dumb enough to mount 315s on a 9.5" wheel.
File Type: jpg 307327178_4172496272974906_3708339575162811925_n.jpg (50.5 KB, 39 views)
Old 02-01-2023   #9
Its a 9.5, you can fit a 315 on those with no issues
