Old 08-18-2022   #11
jrd1990zr1
jrd1990zr1's Avatar
Default Re: Brake petal goes low intermittently
Originally Posted by conesare2seconds View Post
Tricky part of the MC replacement is the C-clip from the pedal to the rod. You?re upside down with your head in the footwell and it?s dark even with a good light. Be patient, it will work.
If the booster is good, do I have to remove it and disconnect from the pedal? I thought the MC is bolted to the booster and you separate it there? Am I mistaken? Thanks.
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 08-18-2022   #12
You can remove the MC without removing the booster. Pretty simple.
Old 08-21-2022   #13
jrd1990zr1
jrd1990zr1's Avatar
Thanks, I thought so. Not sure what the other guy was saying about removing it from the brake petal.
Old 08-22-2022   #14
Stingray1967
Stingray1967's Avatar
Is the ZR-1 master cylinder any different than the base engine master cylinder?
1967 Corvette convertible, L79, 4 speed, red / black / white top
1994 Corvette ZR-1, white / black
NCRS North Central Chapter Judging Chairman
Stingray1967 is offline   Reply With Quote
Old 08-22-2022   #15
There are variations depending on years. Whether interchangeable between standard C4 vs. ZR1s, I don?t know.
Old 08-22-2022   #16
https://corvetteparts.com/catalog/Da...aster+cylinder
According to above, perhaps 92 to 95 had minor difference (fluid reservoir?) specific to ZR1s.
Old 08-22-2022   #17
jrd1990zr1
jrd1990zr1's Avatar
Mine is a 1990. Shows up on page 1 of that link.
Old 08-22-2022   #18
conesare2seconds
Sorry, I was thinking of the clutch master. My bad.
