Old 08-06-2022   #1
davidijaxson
Default New Fuel Pumps
I contacted the PO of my 90' car and the fuel pumps have never been changed. I am thinking I should replace them as a preventive measure.
I believe I will use the Delphi FE0039 pumps unless someone knows of a reason why I should not.
I wanted to ask if there is anything else you would recommend replacing while I am making the pump swap.
Thanks for sharing your wisdom.
davidijaxson is offline   Reply With Quote
Old 08-06-2022   #2
Default Re: New Fuel Pumps
I switched to single pump after I bought the billet Y connector from Carter @ CT Machining. This replaces the brittle plastic Y that will crack and leak in time. You can do a search on the forum for more info. Image1659836988.362480.jpg
$75 shipped in US.
Old 08-06-2022   #3
I?ll take it Craig.
Message me your email for PayPal.
Old 08-07-2022   #4
I?ll take it Craig.
Okay, will do Yun!
Old 08-07-2022   #5
davidijaxson
I?ll take it Craig.
Craig, do you have more than one of the Y fittings? Is that something you put together yourself or can it be purchased?
Old 08-07-2022   #6
Matt B
You may want to consider the complete plug n play single fuel pump conversion kit one of our fellow owners offers.
It's nice, easy to install and eliminates most the issues the dual pump design has.
If you consider 2 new Delphi pumps, socks, Y adapter, submersible fuel lines and new clamps the difference isn't too big.
Matt B is online now   Reply With Quote
Old 08-07-2022   #7
davidijaxson
Who should we contact?
Old 08-08-2022   #8
TX '90 ZR1
Carter makes the "Y" fittings. He is here on the forum as Carter200.
Old 08-08-2022   #9
Sorry, I guess you should have been given first dibs as a reply to your inquiry. As mentioned, Carter sells them here or email him at: ctmachining@gmail.com
As Matt mentioned I would go with the single fuel pump with stainless housing and all brand new parts. I just assumed you were trying to keep it original.
Old 08-10-2022   #10
Matt B
Flyman 27 is the one to get in touch with. His kit is also on ebay if you want to see pictures. But better to buy from him directly instead of making big tech even richer
