Old 05-31-2022   #1
Default Do base c4 wheels fit?
Considering picking up a set for when the car sits over winter to avoid flat spotting issues. My questions are will they bolt up, I?m assuming yes. And will it cause any issues, I?m assuming no. But I?d rather ask and look stupid than damage something in the suspension or cause other issues
Old 06-01-2022   #2
tccrab
tccrab's Avatar
Default Re: Do base c4 wheels fit?
Fronts will work fine, same exact wheels.
Rears will work, just look funny. They will clear the brakes and suspension, but the offset and width will not fill the wheel well at all.
There will be a 2 inch wider gap at the tire and the body panel.
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 06-01-2022   #3
That?s kinda what I thought and I?m fine with the gap. It?s just going to be sitting in the garage all winter on a charger so I don?t care about it looking weird.
Old 06-01-2022   #4
Mystic ZR-1
Mystic ZR-1's Avatar
Why don't ya just store the car on jackstands and save
the expense of extra wheels and tires?
Jackstand storage can be controversial...
Old 06-01-2022   #5
I was under the impression that?s not good for the shocks.
Old 06-08-2022   #6
Young1
Young1's Avatar
Set the jack stands on the suspension components to keep the springs loaded. Too much work moving wheels around and storing them.
Steve Young
Second Owner
SOLD
SOLD
Old 06-14-2022   #7
rkreigh
get some old cheap carpet sample squares. double them up and pull up and you won't flat spot
they make a fancy tire cradle out of foam, but the carpet samples are cheap and ez
95 390 LPE ZR1 (505 rwhp)
