Old 05-19-2022   #11
VikingTrad3r
Default Re: Will 335 35 17 fit up front?
do u happen to know if these rims are still available for purchase? if you didnt purchase them could u connect me to the seller? cheers. VT.
I am trying to figure out how to get a square setup on my 91 zr1
Originally Posted by conesare2seconds View Post
I came across a set of A-molds that have been widened to 17x11 up front and 17x12 rear. They currently have 315/35/17 and 335/35/17 respectively and fit without clearance issues.
At first I thought great, I can run the Michelin Pilot 335/35/17 out back. But the wider front becomes a problem since it is not offered in a 315.
I know a 315 will fit up front but ive never seen anyone run larger. If the only tires I can run are R-compound, I will pass on the wheels.
The other option would be to stick with the 9.5s up front, but then I don?t need the 12-inch rears to fit a 335.
Is there a good option for these widened wheels I haven?t thought of? Kind of thinking I should pass them up and put the dollars toward a set of CCWs in 18f/19r down the road.
VikingTrad3r is offline   Reply With Quote
Old 05-20-2022   #12
rkreigh
I have a set of CCW black center classics 17X12 up front and 17 X 12.5 in back
they have an older set of hoosiers mounted up. PM me if interested.
Not cheap but they allow 315 up front and 335 in back on the z
Old 05-25-2022   #13
NVRL8TE
They will fit.
Just know, that Ive ran a 315 square setup before, and the front tracks pretty good.
NVRL8TE is offline   Reply With Quote
Old 05-26-2022   #14
conesare2seconds
VikingTrad3r:
Brian Foster
bfoster50620@gmail.com
