Old 05-03-2022   #11
spork2367
Default Re: no spark
Sensor tested good (at the sensor). Interestingly, it has a shim despite being outside the "first 500" range.
Old 05-03-2022   #12
JG95ZR1
JG95ZR1's Avatar
What year is the car? Did you check the fusible link powering the ECM by the battery ?
JG95ZR1 is offline   Reply With Quote
Old 05-03-2022   #13
JG95ZR1
JG95ZR1's Avatar
I had this issue on a barn find 91 so I have been threw these series of test, mine was a slight Bent pin and corrosion on the DIS wire harness connector.
Old 05-04-2022   #14
spork2367
The injectors seem to be firing, so ECM would have power.
Had the connectors out when I swapped in the other DIS to test, but I'm leaning towards a chewed wire/short, or corrosion on a connector. I had put dielectric on all the seals under the plenum last time I had it apart to do injectors.
Old 05-13-2022   #15
spork2367
Still no spark. Running out of things to check. All wires on engine bay side test good.
Old 05-13-2022   #16
Corvette95
Corvette95's Avatar
Does your check engine light come on solid with key on engine off?
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 05-13-2022   #17
spork2367
Yes.
Old 05-13-2022   #18
HAWAIIZR-1's Avatar
No spark, but at least you have spork!
Sorry, I could not help myself. I won?t quit my day job. [emoji38]
Nothing to add, but I hope you get it resolved.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 05-13-2022   #19
Originally Posted by spork2367 View Post
Yes.
It should flash once before solid light.
Old 05-13-2022   #20
spork2367
Stick a spork in me I'm done!...lol.
It does.
