Old 09-26-2021   #1
kieranod1
Default Engine quits after 7 minutes
Hi guys, when I cold start my 91 ZR1 she runs for approximately 7 minutes(warm up time) then shuts down. After that she starts right up for 6 seconds and shuts down. When she completely cools down I can start the whole process all over again, any thoughts?
kieranod1 is offline   Reply With Quote
Old 09-26-2021   #2
Default Re: Engine quits after 7 minutes
good chance its O2 related its moving from open loop to closed loop, when its under 160 or so degrees it runs off a pre determined startup program, when it warms up it moves to running off the 02 sensors, and if they or the wiring is bad it will go rich or lean ... killing the car. I would bet if the car starts to stall and you gun the motor it comes right back because its going back to open loop
Old 09-26-2021   #3
kieranod1
Thanks I'll try that.
Old 09-26-2021   #4
Scan tool would help ID the problem
Old 09-26-2021   #5
kieranod1
I'm not getting a check engine light and I'm not of a scan tool for OBD 1's. I do have a MaxiDAS DS808 reader with an OBD 1 adapter but still doesn't see anything.
Old 09-26-2021   #6
Sounds to me like a primary fuel pump has failed
Old 09-26-2021   #7
Was thinking the same thing..
Old 09-26-2021   #8
kieranod1
I thought so also and replaced both fuel pumps and filter but still the same result.
Old 09-26-2021   #9
Did you check the fuel pump relays as well?
Old 09-26-2021   #10
kieranod1
I'll get her up on the lift and check it out when I get back home. Thanks guys!
