Old 09-11-2021   #1
Erik
Default WTB: R-D Racing Cross-Bar
Hi folks
Looking for the old R-D Racing Cross-Bar. This is the one that goes across the car, behind the seats. Looks like this:
File Type: jpeg 008E0EB6-F519-4AD8-990C-5056251BF26A.jpeg (43.1 KB, 74 views)
1990 ZR-1 # 996
Old 09-12-2021   #2
Default Re: WTB: R-D Racing Cross-Bar
Originally Posted by Erik View Post
Hi folks
Erik the Brey-Krause is a superior bar have you looked at one of those. GC
Old 09-12-2021   #3
conesare2seconds
I?ll need to check but pretty sure I have a spare Cross Bar. I?m in the middle of a move but will be over at the new house tomorrow. It did not come with mounting hardware when I bought it.
Old 09-12-2021   #4
ZRXMAX
ZRXMAX's Avatar
Hi Eric
I built my own a while back and it bolts in at the upper seat belt bolt and also at the roof carrier mounting points. ( 4 points of attachment ) I am pretty sure I still have your number so I can send you pictures of it. The main bar meets the thickness requirement though I have not drilled a small hole in it so the tech guys can check it. I sold my Z so I can't take a picture of it when installed. My car was a 91 and I believe the distance to the mounting points is the same as yours.
91 ZR-1 #661 Watsons, 3" exhaust, Borlas... Hurst, 4.11s, Samco, RD radiator, gel coated motor... turquise / black
ZRXMAX is offline   Reply With Quote
Old 09-12-2021   #5
Erik
Awesome!
Thanks
1990 ZR-1 # 996
Old 09-12-2021   #6
Erik
I have not. Not familiar with those at all. Time to take a look!
Thanks
1990 ZR-1 # 996
Old 09-12-2021   #7
Erik
Originally Posted by ZRXMAX View Post
Hi Eric
I built my own a while back and it bolts in at the upper seat belt bolt and also at the roof carrier mounting points. ( 4 points of attachment ) I am pretty sure I still have your number so I can send you pictures of it. The main bar meets the thickness requirement though I have not drilled a small hole in it so the tech guys can check it. I sold my Z so I can take a picture of it when installed. My car was a 91 and I believe the distance to the mounting points is the same as yours.
Excellent! Looking forward to it.
1990 ZR-1 # 996
Old 10-02-2021   #8
Young1
Young1's Avatar
Check out Exotic muscle. They have a bar. RK appears to just do engines now. Brey Krause system looked excellent and you can retain stock seat and belts with appropriate brackets. Bolts in to existing points. Should stiffen the car some too.
Steve Young
Second Owner
SOLD
SOLD
Old 10-03-2021   #9
HAWAIIZR-1's Avatar
As GoldCylon and Young1 mentioned, the Brey-Krause is an outstanding, high quality product and top-notch as far as I am concerned. I had the Hardbar and replaced it with BK. Here are some photos of my install if it helps.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 10-03-2021   #10
HAWAIIZR-1's Avatar
Brey-Krause bars have the loops for the harness and the bracket on the side and front of the seats for 6 point. Very clean and allows use of stock seat belt.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
