Old 07-26-2021   #1
vetteguy48
Default 90 ZR-1 Quit
Hey everyone..looking for some advice. Driving my 90 ZR-1 (12.5k miles) to work this morning and it suddenly quit. it felt like it just ran out of gas, but no sputtering...rpms just dropped to nothing and then out. coasted to the side of the road and tried to restart...but it just cranked away. Full tank of gas and no other issues have every popped up. I have owned the car for a year and put about 2K miles on it with no problems. Anyway the only thing i was able to glean from searching other posts was possible problem with fuel pump lines coming off in the tank. Had the car towed to our local Vette shop here, which happens to be closed today, and will talk to them tomorrow. Any other thoughts from you would be super appreciated.
vetteguy48 is offline   Reply With Quote
Old 07-26-2021   #2
Matt B
Matt B's Avatar
Default Re: 90 ZR-1 Quit
Check if the car starts when cold and let it idle to warm up. During start up and cold coolant both pumps work whereas the secondary will shut down as coolant warms up. So if the engine stops the primary is likely to be out.
For sure the pros here also have more sophisticated procedures but this should be a good starting point.
Good luck!
Sent from my SM-G991B using ZR-1 Net Registry mobile app
ZR-1 #638/1991
Old 07-26-2021   #3
PhillipsLT5
PhillipsLT5's Avatar
Primary fuel pump bad? Try the fuel pump jumper from Jim voter
Old 07-26-2021   #4
vetteguy48
Thanks for the tip. I did try and start it again after we towed it to the shop (they're not open today). No luck. I'll pass the information on to my mechanics when they get to work tomorrow. Any other tips really welcome. The shop in Olympia (Capital Corvette) is really good and super supportive, but have limited experience with the LT5 so help is appreciated.
Old 07-26-2021   #5
vetteguy48
Just read the Jim Voter posts. Great stuff. I will try and reach out to him. thanks
Old 07-30-2021   #6
Fuel-Air-Spark?
Nothing to add to what Jim Voter may have said/written, but am curious to hear what you finally come up with!
Old 08-01-2021   #7
QB93Z
QB93Z's Avatar
Your jumper is on the way to you. For some long-distance trouble shooting, how long did the ZR-1 run before it stalled?
Old 08-01-2021   #8
I think coolant temp triggers secondary pump shut off. If I remember correct, 167 degrees.
Old 08-02-2021   #9
QB93Z
QB93Z's Avatar
That is what I remember also, I was hoping to determine if the engine quit at about that time interval so we could "confirm" a failed primary fuel pump at cold startup.
