Old 06-24-2021   #1
mlipmd
Default suggestions on radio repair
As is typical, on my '90, the radio was non-functional when I got the car, most likely due to leaking 31 y.o. capacitors. The head unit itself seems operational because the antenna goes up and down, the clock works, AM/FM works, stations can be selected and scanned, the cassette works and ejects properly but no sound comes out, and I got 12V at the speaker wires, so I don't think that or the computer under the PS dash is the problem. I removed all the amps and 2 of them were badly burned probably from leaking caps causing a short on the board, and they were sent to Bose Central in FL for repair. 3 of them were repairable i was told, one beyond repair and needed replacement with one of their refurbished units. I got them back yesterday and hooked them up today and no sound comes out of three of them and only very faint sound out of one in the right rear (which I think was their refurbed one, the other 3 my originals). I have contacted them but have not heard back yet.
What do you think is the likelihood that it is the CDM under the PS dash as the problem? From what I have seen online, that is a real PIA to get out and I really don't want to do that if I can avoid it.
Has anybody else had experience with Bose Central?
Edit - Just got a call from Kurt at Bose who swears it is the CDM now causing my problem. It has the same old capacitors that also can leak inside that unit so he wants me to pull it and send it in to him for repair. They also have new ones and I just may bite the bullet and get one of those so I don't have to fuss with this again. He says he got those new units from Bose and the capacitors are good despite their age because no juice has flowed through them and it is the heat from use that makes them leak. Sitting on a shelf for all these years according to him, does not damage them. Any thoughts about any of this?
Stay tuned.
mlipmd is offline   Reply With Quote
Old 06-24-2021   #2
TX '90 ZR1
TX '90 ZR1's Avatar
Default Re: suggestions on radio repair
Dollars to do-nuts, I bet it's the "computer" under the dash. CDM or DCM it is called. Never can remember which!
I've used Dr. Don and have nothing but good to say about him. No personal experience with the other place, but have heard they are good also.
If you have to take it out, do a search for CDM (DCM) removal and also post up here on the forum. A lot of us have removed them and will give you some pointers as well as moral support which you will definitely need!
Kenny
1990 #442
Old 06-24-2021   #3
cadillac531
cadillac531's Avatar
When speaking to Dr. Don today, he was telling me the radio module is behind the passenger seat and not very hard to get to. That may be what your issue is. Did you look there?
Constantine
Registry Founding Member #0235
1991 Corvette ZR-1 -- Stock, 94 ZR-1 exhaust system, muffler delete.
1956 Chevrolet Belair -- Pro Street, 531ci Cadillac, 8-71 Blower, 8pt roll bar, built TH-400, 9" rear, 1,100 HP -- Street Car.
https://www.youtube.com/watch?v=z8y4cwcvK0s
1968 Mustang "Pegasus" -- Zeeker Chassis, 584ci Dart Block, Brodix Big Brodies, 2-1150 Dominators, FTI 'Glide, 1168 hp, best ET & Trap(holding back) 8.57@159 -- 7.9X -- 1/4 mile car.
1970 Chevelle -- 468ci, TKO600, shaved and smoothed everything.
cadillac531 is offline   Reply With Quote
Old 06-24-2021   #4
TX '90 ZR1
TX '90 ZR1's Avatar
Unfortunately, the '90's are in the passenger side of the dash. Later years, not sure exactly when, were moved to the compartment behind the passenger seat.
I bet some GM employee had to remove one and raised so much hell they decided to move it!
Kenny
1990 #442
Old 06-24-2021   #5
mlipmd
I'm thinking of getting a new unit from them (see edited post above) so when I remove the old one, I already have another in my hand so I can remember how to replace it.
Old 06-25-2021   #6
TX '90 ZR1
TX '90 ZR1's Avatar
Read your edited post.
Not to doubt anyone, but I would be inclined to get a second opinion on using a 30 year old unit, used or not. I was always of the understanding that the problems were more a function of age instead of use. If not, why do a lot of the really low mile cars have non-functioning radios?
Believe me, you do not want to remove the unit but one time.
Kenny
1990 #442
Old 06-25-2021   #7
dredgeguy
dredgeguy's Avatar
Get it repaired or replaced by Dr. Don....he is the man when it comes to Bose. Do yourself a favor and send him the head unit and have him put an aux input on it so you can plug in a XM radio or your phone for perfect clear sounds and still retain the stock look
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 06-25-2021   #8
mlipmd
I believe you guys are right - I am going to get my CDM repaired (with new caps) rather than relying on ones that are NOS but 25-30 years old.
Going to dig mine out today and dreading it, but that's the only way to fix it and keep it original.
Old 06-25-2021   #9
TX '90 ZR1
TX '90 ZR1's Avatar
I believe this is the wise and correct decision. Good luck.
Kenny
1990 #442
Old 06-25-2021   #10
bowtiguy
I had a full Bose rebuild done on my 91 NCRS car for $700 through https://www.carstereohelp.com/ 2 years ago, but he is closing for the summer 2021.
Dr. Dons turned around the complete system on my current car in quick order, but it was $1100 including the aux input.
bowtiguy is offline   Reply With Quote
