Old 05-07-2021   #1
1971 Judge
Default C7 brakes on a 90 ZR-1?
Gents,
I'd like to upgrade my front brakes on my 90 ZR-1.
Some initial research shows that the C7 front caliper "can" work on our cars. There's a thread on the Corvette forum where a gentleman did c7 calipers/aftermarket rotors and a spacer.
Anyone here done this already? Open to recommendations.
I currently have 19" Forgestar F14's on all (4). So, clearance won'te be an issue.
Thanks in advance!
1971 Judge is offline   Reply With Quote
Old 05-08-2021   #2
Default Re: C7 brakes on a 90 ZR-1?
I have C6Z brakes on my 92.
Old 05-08-2021   #3
I went with Wilwood 6 pistons front and 4 pistons rear.
https://www.zr1.net/forum/showthread.php?t=24546
Old 05-08-2021   #4
1971 Judge
Did you have to do any fabrication - or puchase additional parts (minus calipers/rotos) to do the swap? Thanks.
Old 05-18-2021   #5
sleazy rider
i installed a set of c6 z06 rotors/calipers/wheels and tires on my 91 zr-1. open this link and go to post #3. to mount a set of c7 calipers i would think that you would only need to find someone to manufacture a set of brackets as the bolt distance is different from the c5/c6 bolt pattern.
https://www.corvetteforum.com/forums...c4-zr-1-a.html
sleazy rider is offline   Reply With Quote
Old 05-18-2021   #6
The fronts are easy enough w the installation of an adapter bracket on the spindle and correct brake line. Of course this assumes use of 18? wheels w the proper clearance. The rear calipers require either an adapter or use of adapter from Street Shop. The Street Shop adapter allows u to retain the eBrake. Expensive but worth it IMO.
Here?s a thread outlining the conversion. Apologies if its a dupe.
https://www.corvetteforum.com/forums...onversion.html
