Old 04-14-2021   #1
Shizap
Default Cam Cover Removal Question
Hello,
I am planning on removing my cam covers because they are leaking. The factory service manual says to drain the coolant so the coolant outlet pipes above the covers can be moved out of the way. Is this a requirement? It seems like I have enough room to take off the cam covers without moving these which would mean I don't have to mess with the coolant. Am I missing something? I am not pulling the plenum, only the cam covers. I also have the headers offs and the engine tilted if that changes anything.
Thanks,
Scott
Shizap is offline   Reply With Quote
Old 04-15-2021   #2
G8nightman
G8nightman's Avatar
Everything came off even brake booster and the evaporator cover
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 04-15-2021   #3
Shizap
Default Re: Cam Cover Removal Question
Yes, I am aware of the evaporator cover and brake booster. My question is if the coolant outlets need to be removed like the manual states. If they don't, then I wouldn't have to drain the coolant, correct? I don't want to pull the plenum or mess with the coolant if I don't have to.
Here's a picture to show you what I mean
Thanks,
Scott
Old 04-15-2021   #4
G8nightman
G8nightman's Avatar
You have to pull the plenum to lift the compressor lines unless your going to recharge the Ac
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 04-15-2021   #5
Shizap
Yep, right now I am leaning towards recharging the AC as I suspect the system is low and could use it anyway.
