Old 02-11-2008   #1
Captain A
Captain A's Avatar
Default Wire Question
I am putting in a power antenna bypass switch so the antenna won't go up with the cd player in use. Which wire color do I look for? and which harness do I look in near the back of the car? Thanks
Captain A is offline   Reply With Quote
Old 02-15-2008   #2
Captain A
Captain A's Avatar
Default Re: Wire Question
For future ref. for all of you, it is the green wire that is on the conector opposite to the 2 pink wires on the conector under the plastic cover in the back of the car. Now when I use my bose system and am using casette,cd or Ipod ,my antenna won't go up causing it to wear out. I put the on/off switch under the drivers seat. Now onto my next mods....moving my air sensor and battery relocation.
Old 02-15-2008   #3
Nick
Thanks for the wire location tip. The antenna switch is a cool mod. What switch did you use?
Nick
ZR-1 Net Registry Founding Member #32 - lapsed...
Old 02-15-2008   #4
Captain A
Captain A's Avatar
I used a switch from mid america for the c-5's. I am sure most togle switches would work. Either pull the fuse or disconect the battery when splicing the green wire.
