Old 03-06-2021   #11
Matt B
Matt B's Avatar
Default Re: Brake pads- too much dust- need some current choices
Not sure if there is anything similar available on the US market but on my Audis I'm using ATE Ceramic pads. These are extremely low on dust and the very few emissions are light grey-ish. Nearly invisible on standard rims. After about 12kmls there is literally no break dust on my 20" wheels. Amazing stuff, highly recommendable!
They are compatible with all standard discs, so no special requirements and deliver stopping power as good quality parts should.
ZR-1 #638/1991
Old 03-06-2021   #12
conesare2seconds
I never had much dust with Hawk HPS even running frequent autocross with my old 95 LT1. I just put on HPS 5.0 to replace whatever was on my car when I bought it, hope they?re about the same.
Old 03-07-2021   #13
Corvette95
Corvette95's Avatar
I thought Hawk were supposed to be low dust.... reading more reviews says otherwise, but I would believe my ZR1 brothers over online reviews...any other Hawk pad reviews for dust?
( other Hawk reviews https://www.svtperformance.com/threa...s-pads.993964/ )
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 03-07-2021   #14
longhorns05
longhorns05's Avatar
Just replaced the front pads on my 94 about a month and a half ago with Hawk HPS pads. So far there's been very little brake dust and no noise that I have noticed.
93 ZR-1 Red/Red 415ci
Jeal cams/headers, hf cats, B&B
Wilwood brakes, DRM coilovers
94 ZR-1 Red/Blk 368ci
SW headers, hf cats, Corsa
16 GT-R Blk/Blk Stg1 3.8
BL1200X, Shep1k, Motec
1250 whp on pump e85
longhorns05 is offline   Reply With Quote
Old 03-13-2021   #15
I've been running Akebono brake pads for years and brake dust is pretty much gone.
Old 03-14-2021   #16
lfalzarano
You?re braking too much! Just use the right pedal![emoji108]
Lou[COLOR="Red"][B][SIZE="4"][/SIZE][/B][/COLOR]
Old 03-14-2021   #17
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Very good Lou!
In New Jersey the brake pedal and the horn are synonymous, choose either.
Marty
Old 03-14-2021   #18
lfalzarano
Default Brake pads- too much dust- need some current choices
I grew up in Jersey. Never blow the horn! Just blow by the slow poke when they aren?t looking. High speed draft and pass. Maybe a gesture!
But in the city, the horn is required!
Old 03-14-2021   #19
bowtiguy
The wifes AMG GL63 brakes dusted like CRAZY when new, each drive the wheels would get visually darker. At 8,900 miles, I had enough. I called Hawk and asked if they had the backing plate specs and if they could make a pad for it. They said yes and chose the HPS compound on all four corners.
We've Put 15K miles on it since then and the only reason I wash it now is dust ON TOP of the car. Better brake pedal feel and modulation too.
I run the HAWK LTS pads on our hummer H3 alpha. Just had to put new pads on it. Fronts last 60K ish, rears 130K ish.
bowtiguy is offline   Reply With Quote
Old 03-15-2021   #20
WydGlydJim
WydGlydJim's Avatar
what is this brake dust you speak of..
2009 LS9
1990 LT-5/sold/Bought my Baby back
1994 Lingenfelter LT-5/sold
1973 LS4/sold
WydGlydJim is offline   Reply With Quote
