Old 12-07-2020   #81
Thomas ZR-1
Thomas ZR-1's Avatar
Default Re: Revision Corvette ZR-1 model year 1990 #125
Thank you for the offer but I`m not sure what you are talking about...can you post a picture of that item?
[SIGPIC][/SIGPIC]Best thing in life is a ZR-1 ride
Thomas ZR-1 is offline   Reply With Quote
Old 12-07-2020   #82
Thomas ZR-1
13. Installation powertrain
Before the engine could be fitted back into the car the transmission tunnel was covered with heat protection foil to reduce the temperature level inside the car caused by the exhaust gas system.
Old 12-07-2020   #83
Thomas ZR-1
The assembled engine was pre-lubricated with engine oil by the oil pressure sensor hole with an electric pump.
Old 12-07-2020   #84
Thomas ZR-1
After 6 months the engine was finally back where it belonged.
Old 12-07-2020   #85
Thomas ZR-1
Flywheel, clutch with a new disc, a new clutch bearing and the bell housing with a new slave cylinder were installed.
Old 12-07-2020   #86
Thomas ZR-1
The old connecting pipe between the clutch master and slave cylinder was replaced with a new stainless steel covered Teflon hose. The slave cylinder bleeder was exchanged for a further stainless steel covered Teflon hose ending at the hood lock on the driver side for an easier fluid change.
Old 12-07-2020   #87
Thomas ZR-1
The 6-speed transmission with cardan shaft and transaxle C-beam followed.
Old 12-07-2020   #88
Thomas ZR-1
Wiring harness, diverse pipes and hoses were connected.
Old 12-07-2020   #89
Thomas ZR-1
The OEM exhaust gas manifolds and catalytic converters were installed.
Old 12-07-2020   #90
Thomas ZR-1
The engine was covered with the plenum.
