Old 10-09-2020   #531
32valvZ
32valvZ's Avatar
Default Re: TB removal and then some!!!
Are you going to paint the front and back sides of the rotor hats? I always do that... prevents rust that looks ugly.. I even paint the "spine" of the rotors where the cooling fins are...
Old 10-09-2020   #532
Roadster
Roadster's Avatar
Yes I intended to do that....might go with high temp black.... [emoji16][emoji16]
Sent from my SM-G981U using ZR-1 Net Registry mobile app
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 10-09-2020   #533
Roadster
Roadster's Avatar
When I purchased my 94 back in 2014....one of the first changes I made...was to buy the chip from Marc Haibeck for the HP increase and fan operation...it was then that I discovered that the PROM in the car was different that what I thought would be there....different in the way of the markings on it...it has dates and Tim Holland's name allover it....
I then found out that Tim Holland was one of the Lotus Engineers responsible for setting up the PROM's for the LT5...this one being for the 93-95 versions...
Ended up tracking down Tim at that time and had a great conversation with him...as I also found out that my ZR-1 was a captured test fleet car and owned by GM for 2 years and 27,000 miles later...Tim started laughing and said..."that chip wasn't supposed to be left in the car, it was to be removed"...but he also mentioned that it was fine to be there...as that is the final version for the stock PROM's for 93-95...
He also mentioned that they drove these captured test fleet cars everyday just like a regular family car...went to the store, drove family members where they had to go...etc...etc...and IIRC when parts went bad if that happened....they were readily replaced....I am assuming that Tim might have used my car himself...since his PROM was in there...hopefully sometime in the future I will talk to him again...
Here are some pics... [emoji16] [emoji16]
Pic #1....the PROM cover...
Pic #2....BKKR....Tim's name and date....
Pic #3....closeup....
Pic #4....Tim Holland's name allover the PROM...
Pic #5....and date markings....
Pic #6....Marc's chip added on....20201009_124928.jpg20201009_121627.jpg20201009_121633.jpg20201009_121704.jpg20201009_121653.jpg20201009_121723.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 10-10-2020   #534
Roadster
Roadster's Avatar
Keeping myself busy....just finished painting the rotors....worth the time to mask....they turned out good....
Pic #1....front all tapped and ready...
Pic #2....rear done...
Pic #3....mim thickness 26.4mm
Pic #4....there are L & R part #'s for the rotors....I imagine for Assembly Line purposes.... LS part #
Pic #5....RS part #
Pic #6....out in the outside open paint booth....it works...20201010_121616.jpg20201010_123953.jpg20201010_124601.jpg20201010_124541.jpg20201010_145424.jpg20201010_133118.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 10-10-2020   #535
Roadster
Roadster's Avatar
Finished....the rotors just need a good wipe down with Brake Clean before install....
Pic #1....happy with the results....
Pic #2....even shot the caliper bracket....20201010_153131.jpg20201010_151938.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 10-10-2020   #536
ZR2
Pretty cool about the chip. A neat piece of history!!!
ZR2 is offline   Reply With Quote
Old 10-11-2020   #537
Roadster
Roadster's Avatar
Yes it is.....thanks....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 10-12-2020   #538
32valvZ
32valvZ's Avatar
Looking good... I also used silver. You really took some time on them with the tape... I wire wheeled them with my air die grinder and a steel wire wheel, balm canned them and wiped the braking surfaces down with some brake clean on a rag...
Old 10-14-2020   #539
Roadster
Roadster's Avatar
Looking good... I also used silver. You really took some time on them with the tape... I wire wheeled them with my air die grinder and a steel wire wheel, balm canned them and wiped the braking surfaces down with some brake clean on a rag... =D>
Thanks....actually the tape didn't take that long.... I'm better off without the wire wheel on some items....lol
Still have to take the back ones apart and get them cut....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 10-14-2020   #540
Roadster
Roadster's Avatar
Between everything else going on....still working on the LF suspension wheel well area....slow but steady progress and plenty left to do...with 26 years of grease and crud buildup ..
Pic #1...making progress..... just to look clean again....
Pic #2...LF shock part#....
Pic #3...continuation of part#....
Pic #4...have no clue what the 7C sticker means...20201014_175624.jpg20201014_174704.jpg20201014_174736.jpg20201014_174840.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
