Old 09-02-2020   #501
Roadster
Roadster's Avatar
Default Re: TB removal and then some!!!
Originally Posted by dredgeguy View Post
Good to see you back Tom! As always, great job
Thanks Charlie, hope to see everyone real soon....[emoji16][emoji16]
Sent from my SM-G981U using ZR-1 Net Registry mobile app
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-02-2020   #502
Roadster
Roadster's Avatar
Originally Posted by BigJohn View Post
How is the 74 running now that it is finished?
Hello John....first startup went really well with the 74....but need to address the exhaust issue I am having with the exhaust manifold pipes not going in the configuration that I would like them to be under the car....around the trans......also need to work on the ZR-1 first as I need to put the 74 in that garage slot....so the 74 still is far from finished as the interior is completely out....and still need to change some items in the engine compartment as well...but getting there...thanks for asking....going to sneak in a pic....lol
Intended to do tripower....but then we stayed with the Q-Jet....which is fine...and sold my 68 tripower setup.....then a month later I buy a 67 tripower setup....it's just on my bucket list....so we shall see what happens next year....lol....[emoji16][emoji16]
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-02-2020   #503
nelson007
nelson007's Avatar
Hello Tom,
What media are you using in the Tumber?
Thanks,
Nelson
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
2012 ZR1 Preproduction
Old 09-02-2020   #504
Roadster
Roadster's Avatar
Hello Nelson,
Just a smaller unit that I purchased from HF a few years ago. Large enough to do small parts and brackets. It does a decent job.
Here is a pic of the unit and the media I prefer to use. The results are good, but it also depends on the time spent in the tumbler. You still need to soak and or wipe the media "dust" off the parts to get ready for paint....etc.....[emoji16][emoji16]JPEG_20200902_224629_2269899710058524322.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-02-2020   #505
Roadster
Roadster's Avatar
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-03-2020   #506
BigJohn
BigJohn's Avatar
Attachment 12809
Hi Tom,
You know that driving a big block car gives you a feeling that no other car can.
Take your time and enjoy the process!
Old 09-04-2020   #507
Roadster
Roadster's Avatar
Hi Tom,
Will do John, this is my first Big Bock C3.....in almost 12 years of ownership.. I've only driven the 74 for about 10 minutes....lol Anxious to experience that feeling and also anxious to drive the ZR-1 once again.....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-06-2020   #508
Roadster
Roadster's Avatar
Since I have items out of the engine compartment.....I would like to remove the thermostat housing and replace the thermostat and clean up the housing itself....but the one heater hose connection is giving me a problem....the other heater hose popped out with no problem....so any advice on how to remove this one is appreciated...and I sprayed some WD40 in there.....I also have 2 new quick connects for replacement...I just don't want to break anything in the process...
Thanks for any info...
Pic #1...nice empty space...
Pic #2...the one hose on the left...no problem....but that hose circled...
Pic #3...two to choose from...
Pic #4...bottom view...20200906_115355.jpg20200906_145349.jpg20200906_144133.jpg20200906_144141.jpg
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-06-2020   #509
BigJohn
BigJohn's Avatar
Are you also going to install a larger radiator?
Old 09-06-2020   #510
Roadster
Roadster's Avatar
I have a new radiator......condenser and a totally cleaned out oil cooler to go back in....so I will be ready.....
1974 LS4 454 Vert
1974 L-82 355 Vert.
