07-22-2020 | #1 |
368 LPE/Haibeck Dyno Results
Time for another good dyno report... Marc just finished a round of upgrades on my new-to-me '95 (replaced my wrecked '93 last year). The car was originally modified to a 368 by Lingenfelter, then breathed on by DRM but never reached its potential. Everything was pretty much sub-optimal. Last recorded dyno before sending the car off to Marc was around 420 RWHP. Pretty mediocre for a 368. Pulled 486 SAE RWHP/405 ft. lbs. torque on the dyno yesterday. That equates to 572 crank HP. Not bad for a 30+ year old design. Kudos to Marc for another outstanding piece of work!
'95 ZR-1, aqua/gray, #167 368 LPE/Haibeck, Web cams, Stainless Works headers, B&B Fusion exhaust, 18" Fikse wheels, Alcon brakes, lowered. 491 SAE RWHP. |
07-22-2020 | #2 |
Re: 368 LPE/Haibeck Dyno Results
486 SAE at the tire?
Wow. Impressive. Can beat Haibeck's stuff, that's for sure. At what RPM were peak power and torque?
07-22-2020 | #3 |
Peak torque around 5200 RPM and power basically flat from 6500 to 7100 RPM.
07-22-2020 | #4 |
Wow that is something. Did Mark just computer tune it only? Did he re time the cams?
07-22-2020 | #5 | |
Just a guess, but I'll bet you'll be replacing the rear tires fairly often....... Enjoy the madness!!! 'Crabs
07-22-2020 | #6 |
Pure stock, just a tune... kidding, of course. Top end porting (including siamesed plenum and injector housings), medium weight (20 lb.) flywheel, cams, headers and 3" exhaust. Well, at least the air filter is stock.😏
07-23-2020 | #7 |
When you say "cams"...do you mean stock cams which have had their timing changed or do you mean cams with more aggressive profiles.
If the latter tell us about the cam profiles.
07-23-2020 | #8 |
Wow Dennis! That?s awesome. Enjoy the new power in your new toy!! [emoji1303]🤙🏼
07-23-2020 | #9 | |
Exhaust 222 deg. duration, 0.442" lift
07-23-2020 | #10 |
Are you using the stock clutch with the 20lb flywheel?
1993 ZR-1 #211 Yellow On Beige Beast #2 1992 ZR-1 #427 Black On Black *Sold* 1985 L98 Blue On Blue *Sold* |
