Old 07-19-2020   #1
billschroeder5842
billschroeder5842's Avatar
Default VIDEO- please help with belt noise/rotating noise diagnosis
Hey all- I'm about ready to cry "uncle" on this one... the panel is stumped.
I have several posts up about chasing my engine belt/rotating assembly noise. I've tried several things but nothing seems to work? I included a video as pictures/sound is worth a thousand words.
https://www.youtube.com/watch?v=NGghmnW1PuM
What I have done since last weekend:
- New pulley on belt tensioner
- New belt Continental 4060805
- New AC bearing
- New AC clutch
I have used the "hose to the ear" method and the alternator, AC , PS and water pump all sound good under load with the AC on. I'm not sure about the tensioner- I'm happy to take it off and rebuild but I'd like to "know" that a rebuild is what is required.
As the video demonstrates, the engine sounds pretty "normal" with the AC off, but the moment the AC comes on its "chitty chitty bang-bang".
Any opinions are helpful.
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
[SIGPIC][/SIGPIC]
Old 07-19-2020   #2
lfalzarano
Default Re: VIDEO- please help with belt noise/rotating noise diagnosis
Don?t panic. Someone smarter than me will help. I had a similar issue with the chirping. After troubleshooting for days, I started the car and no noise. It disappeared. That was my good news but no help to you. Not certain on your choice of belt.
Old 07-19-2020   #3
billschroeder5842
Well, I have three to choose from. One with 15k, one with 4k and one with... less than 1 minute. All are in good condition and they all seem different length but the part numbers all check out.
Bill Schroeder
Texas Proud!
[SIGPIC][/SIGPIC]
Old 07-20-2020   #4
I found this video regarding squeaking and how to troubleshoot the source of the cause.
For what it is worth, my belt lasts a couple or 3 seasons before the water trick indicates the belt is squeaking (especially after sitting for extended periods of tiem, e.g., winter storage, etc.) And, the video shows a belt that might address the squeaking belt issue.
https://www.youtube.com/watch?v=AEUe6uKxTv8
Old 07-21-2020   #5
32valvesftw
I had a very similar sound on a different car and it was the idler pulley bearing. Almost sounds like the compressor itself though if the sound goes away when the AC is off. Perhaps it is low on oil? I assume it sounds fine running with the belt removed?
Old 07-21-2020   #6
Corvette95
Corvette95's Avatar
I will say I had a similar issue. Known good belt tensioner. Issue was wrong size pulley on alternator. It was L98 pulley which was too small causing correct belt to be too long. I would check and measure both the diameter of the alternator pulley AND the offset of the pulley from front of alternator housing. LT5's have a spacer, or if you have a Summit pulley the spacer is built in to the pulley. Either will cause your issue.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 07-21-2020   #7
G8nightman
G8nightman's Avatar
Was is making the nose before you changed anything sound like the belt might be to long.Did you compare the two before replacing them?
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 07-21-2020   #8
Young1
Young1's Avatar
OP. You have the correct belt. I just verified that. I need you to check two things.
A. Your alternator pulley diameter should be 2 13/16 inches.
B. Distance between belt surfaces at tensioner pulley should be 3/4 inch.
The panel is ready for your answers sir.
Steve Young
Second Owner
SOLD
SOLD
Old 07-22-2020   #9
Hib Halverson
I watched and listened to that footage. The recording, both video and audio, is not very good, but I get it that you've got this rattling/clicking noise when you enable the HVAC compressor.
You've thrown a bunch of parts at it...belt, tensioner, bearing clutch.
The only thing left is either the compressor itself or you have something touching or rubbing on some other part that is rotating when the HVAC compressor is enabled.
Those would be my guesses and, if it was my noise, that's where I'd go next.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 07-24-2020   #10
billschroeder5842
Thanks guys- I just got my tensioner back from Marc Haibeck today. He did a rebuild for me and turned it around quickly. I do have three different belts to try (they all have correct ID part numbers but have different lengths...WTF?) so we will see what happens.
Bill Schroeder
Texas Proud!
[SIGPIC][/SIGPIC]
