Old 07-14-2020   #1
Subfixer
Subfixer's Avatar
Default Subfixer's Submarine ZR1
Had a wicked storm at work just before quitting time. Drove through not one, but two hugely flooded roads. Water was coming over the hood and into the cowl vents. Water was coming out the AC vents and dripping on my feet from under the dash.
Car kept running like nothing happened. I was extremely fortunate that I didn't hydrolock the engine.
About halfway home on my 60 mile commute, the Climate Control went bonkers. Kept switching fan speeds, turning the rear defog on & off, then it just quit. AC remained on, Front defrost, fans at high speed. Controls unresponsive, but Fan Auto lamp was lit and rear defrost lamp was blinking.
Made it home without any other issues. Once home, car would not restart. Nothing, no starter click at all.
After sitting a few hours, I went out to try again.
Car started right up, all Climate controls working again. Everything working.
This Submarine ZR1 is always surprising me. This is one tough car!
1992 ZR1 #442, 2 tops, White, White, Haibeck 415, 3.90 gear, Coilovers
2018 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black
2021 Audi Q3, 2.0T, 8 spd Tiptronic, Navarro Blue metallic, Pearl Beige
Subfixer is offline   Reply With Quote
Old 07-14-2020   #2
Erik
Default Re: Subfixer's Submarine ZR1
Great story. Great car.
Would have been even better with pictures.
Old 07-14-2020   #3
Jagdpanzer
Jagdpanzer's Avatar
Luckily you stayed above the Z?s crush depth.
Probably wouldn?t hurt to check the engine valley to make sure the starter stayed dry.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 07-14-2020   #4
Subfixer
Subfixer's Avatar
Ran a length of clear tubing as far as I could into the valley When the car wouldn't start. Came up dry and I couldn't suck anything out. Cleaned the drain tube a couple of months ago.
Also checked the oil to make sure it wasn't milky, so looks like no water ingestion.
Old 07-14-2020   #5
Mystic ZR-1
Mystic ZR-1's Avatar
Good thing you?ve got a ?boat motor? 😀
Old 07-15-2020   #6
Corvette95
Corvette95's Avatar
too late to use the term "Wet Vette" but you did have Mercruiser going for you.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 07-15-2020   #7
32valvZ
32valvZ's Avatar
I probably wouldnt have done what you did... you were extremely lucky.
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 07-15-2020   #8
BigJohn
BigJohn's Avatar
Think you should put air dryers in your car and under hood for a few days?
Old 07-15-2020   #9
rush91
I did the same in my 2006 Civic, had no other choice but to drive through about 2 feet of water.....car was fine for about a month. The car was bulletproof until that point. After that the motor seized on my way home from work. That was that..... You got VERY lucky, I just hope you don't have any issues down the road.
Old 07-15-2020   #10
Subfixer
Subfixer's Avatar
I don't plan on ever doing that again....
