Old 07-06-2020   #1
aafc
aafc's Avatar
Default Using a tech 1A
I'am new to using a tech 1 A so my question is.
When using a tech 1 A what type of printer should i use to read and save the
information. I know i can capture the data ,but it will not be saved when tech 1 A is powered down.
Thanks
Old 07-07-2020   #2
Hib Halverson
Default Re: Using a tech 1A
Back in ancient times, you could get a TECH1 printer from Vetronix, but I have not seen one of those in 20-25 years.
It's possible that you could get a T1A to print to other devices but I don't know how you could solve the connectivity issue.
Specifically...what data are you trying to save?
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 07-07-2020   #3
aafc
aafc's Avatar
Well the dyno tests are done i one state and then the chip is done in an
state. So instead of having to write down the basic info on each pull just
print out each run to read later. Or go to a tuner that can do the pulls and
write the chip on site.
This information would be used to set the tune for everyday driving and
occasional trip down the 1/4 mile. This is not a big deal if i cannot print out
the run information.
Thanks
1990 white/black
one of a few 4l8OE eq ZR-1's since mid 2004
Old 07-07-2020   #4
does the tuner need Tech 1 info specifically? maybe a scan with TunerPro or ALDLDroid would be better for them? Have you asked the tuner what they could use?
Old 07-07-2020   #5
aafc
aafc's Avatar
I'am going to make an appointment next week for the dyno runs. In the
time i will record a run to see what my numbers are and write them down.
I added a spacer between the injector housing and air plenum ( 1 in ) to see if it makes any change in my cars tune.
Old 07-08-2020   #6
Godsgift
Godsgift's Avatar
Vetronix printer on Ebay now:
https://www.ebay.com/itm/Vetronix-Vp...UAAOSw5CNemAg6
Mac
MAC
Godsgift is offline   Reply With Quote
Old 07-08-2020   #7
conesare2seconds
Nice find
Old 07-09-2020   #8
Ccmano
Frankly, for datalogging ALDLDroid is a much better solution.
H
Old 07-09-2020   #9
aafc
aafc's Avatar
Thanks, will look into getting ALDLDroid for datalogging after talking to the
tunner.
Old 07-09-2020   #10
tunner.
Do you have a Windows Laptop? if so just buy a USB ALDL cable and use TunerPro.. either way will work.. both TunerPro sand ALDL Droid use the same config files
