![]() Join Date: Apr 2007
Well after 8 years of trouble free operation of my Direct Lift Pro Park 8S four post lift, I noticed that one of the twisted wires in one cable looked loose. A little hard to see in the picture but was obvious to me when operating the lift the other day. Called Direct Lift, got a local installer recommendation,called them and they will be up first thing next week to replace all the cables. Total cost about $750 but of course worth it. After spotting the cable problem I used the lift one more time to swap cars to get the BMW sedan down and will now wait for the repair before using it again. Should be good for another 8 years or so, by which time it will probably be my heirs' problem.... --Bob
2016 Long Beach Red Z06 #10281 "POPS Z" 1995 Polo Green #409 "WARP TEN"--Haibeck 350/510 package, 4.10s, Hurst, Stock Exhaust with QTP Cutouts --Sold but still running strong 1993 Quasar Blue #161 "HIL KING" --Sold but still running strong, now with more than 120,000 miles 1967 Marlboro Maroon/Saddle Corvette Coupe 300 hp/4-spd --Sold a long time ago ZR-1 Net Registry Founding Member #95 NCM Lifetime Member Favorite Quote--Attributed to Mickey Thompson: "Too Much Horsepower is Almost Enough" Last edited by WARP TEN; 04-10-2020 at 12:31 PM. |
![]() Join Date: Nov 2011
Broken wire rope could be a big problem.
I agree. As soon as I noticed it I called the repair folks. When one strand of a wire rope pulls out of a swage fitting it potentially can mean that the others will loosen shortly and the whole cable will pull out of the swage. The primary mechanical safety stops on the Direct Lift are substantial, with additional backups to them, so I am not worried that the top car would fall down more than the six inches between stops if it let go. But it would be an extra pain to have to somehow jack it up for repair. After I noticed it I used it once more to swap cars and get the BMW down and put the Z06 up. I did notice while lifting that by putting strain on the remaining strands in that cable that the loose one seemed a bit looser--I could see light under the one strand. But it didn't give way. Still, I don't want to use it any more and I am all set until the repair sometime next week. Besides the weather is cold and not conducive to a spirited Z06 drive.--Bob
![]() Join Date: Dec 2003
Crimp should be the last component to fail, if it was done correctly. It's just a dead pull, no flex. Typically, cable problems appear at the section which runs over the sheaves, and appear as broken strands from flex & wear.
I agree, Jerry, that swage crimp failure is not common, but I have seen it before in other applications, and the repair folks said they have seen it before in a other brands of lifts as well. When they change the cables next week I will inspect where they contact the sheaves but so far my regular inspections have not turned up any broken strands anywhere. I have found the other three swages to be fine, but I am replacing all cables just to be prudent. And the one that loosened up lasted 8 years and was probably used in this condition for a while before I noticed it. So I am not too unhappy that I need to replace the cable set. I figured that at some point I would have to do some maintenance like this. So far, including the new cables, my lift cost will have amortized out at less than $500 per year, which I consider OK. --Bob
#6 | |
The good thing is... your sharp eye and attention to detail caught it before something really bad happened. It's just a thought, but 2 things crossed my mind; 1. Are the replacement cables going to be tested before they are installed? 2. I wonder if there is any benefit or detriment to applying some high strength Loctite product to the cable before it is crimped in place. Off hand, only detriment I can think of is the cable end test should be delayed until past cure time.
#7 | |
As to your two questions, I do not know if the cables are all tested or perhaps randomly tested when manufactured. I presume that some sort of verification of the strength of them was done at some point. And while I will defer to more talented engineers here, I would think that putting anything, even Loctite, between the swage and the cable would be detrimental to the pressure and friction bond between them. Kind of like putting some anti seize lubricant on a spark plus changes required torque settings. But that is just a guess. --Bob
A follow up. The main distributor (and owner of Direct Lift) Rotary says they are short one cable so it will be a week or two until I get my cables replaced. If it drags out too long I may go for three cables for now, unless of course the missing one is my broken one. Oh well, we'll see, And Jerry, I spoke at some length with the technical support guy at Direct Lift and he agreed with you that the more common cable failure is fraying of individual wires around the sheaves, but he has seen the larger twisted wire swage loosening I have a half dozen times or so in the last four years. So it is less common but still happens. Overall the lesson here for lift owners is, inspect your lift cables regularly just in case. --Bob
An update on my lift cables. Finally had them replaced yesterday. The manufacturer Rotary (which owns Direct Lift) has been slowed by the virus. But it is done now and seems to work fine. I took a couple pictures of the cable after removal in which one of the large strands had loosened at the swage. A somewhat unusual failure but still one the repair guy had seen before. It was only on one of the four cables and none of the cables showed any signs of fraying. The repair man and I also talked about a couple of things besides my cables so I thought I would pass along his comments for whatever they are worth. First, on my very slight hydraulic cylinder leak, he said it is quite common to have such a leak over time and was not worth worrying about. He claimed that there is a tiny air pressure relief hole that can sometimes seep a little bit of fluid. (Don't know about this as I have never looked at mine that closely). My leak seemed to be from the seal, although I have not noticed any leaking lately. (I use one of the plastic drip trays under the end of the cylinder--it snaps in perfectly under the ramp). He checked the fluid level and said it was fine (after eight years). I could probably top it up by about a half to one inch but haven't done so yet. Second, he brought up lifts with chains rather than cables regarding failures. I have no opinion on one over the other, but the repairman (who services a lot of car dealerships) said the the difference between a chain and a wire cable is that the cable will show wear via either fraying or a strand loosening and therefore provide an advance warning of a need for replacement before there is a problem. A chain he said fails without any warning. You can look at it but can't see an impending failure; it just lets go. Now despite his comment I am not aware of any home lifts with chains that have failed and as he noted, the home lifts don't get near as much use as commercial lifts. And I presume all of our home lifts have robust safety stops (my Direct Lift has primary and backup secondary stops). Lastly he offered one interesting suggestion that might be of interest to owners of Direct Lift and other lifts. I don't know about other lifts' hydraulic fluid tanks, but my lift has a black plastic tank with the fill level mark being an embossed line on the outside of the container. It is hard to look into the tank and and see if the level is up to the line. He said some folks drill a small hole at the line and put a screw in it. If you ever need to top it up, remove the screw and as you slowly add fluid, do so until the first drop seeps out then put the screw back in. Seemed like a sensible approach although I suppose needed only if fluid is seeping out somewhere else. --Bob
2016 Long Beach Red Z06 #10281 "POPS Z" 1995 Polo Green #409 "WARP TEN"--Haibeck 350/510 package, 4.10s, Hurst, Stock Exhaust with QTP Cutouts --Sold but still running strong 1993 Quasar Blue #161 "HIL KING" --Sold but still running strong, now with more than 120,000 miles 1967 Marlboro Maroon/Saddle Corvette Coupe 300 hp/4-spd --Sold a long time ago ZR-1 Net Registry Founding Member #95 NCM Lifetime Member Favorite Quote--Attributed to Mickey Thompson: "Too Much Horsepower is Almost Enough" Last edited by WARP TEN; 05-14-2020 at 12:01 PM. |
#10 |
Good stuff, thanks Bob!
H ![]() |
