Old 04-26-2020   #21
Default Re: Engine Fire??
Originally Posted by TX '90 ZR1 View Post
Saw this over on CF. Anyone know what happened or if it was a members car?
https://www.copart.com/lot/39842359/Photos
I’m not gonna lie that would make me cry. And then I would buy another one!!!!
Old 04-27-2020   #22
32valvZ
32valvZ's Avatar
PM Sent
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 04-28-2020   #23
Vette Guy
Vette Guy's Avatar
Originally Posted by rush91 View Post
And no telling how much water \ foaming agent was doused on there to put it out.
Having had an engine fire (LT1 when the forged crank broke), as well as Brett (L98 when a fuel line O-ring failed), you’ll find that the hardest part is treating all the corrosion from the extinguishant, vs. replacing damaged parts. Nasty stuff, and it gets everywhere. Inside the car as well as all over the drivetrain. Despite quickly being able to pressure wash everything, I still had massive corrosion which resulted in taking my car down to the chassis- Everything had to come out/come off. Clutch looked like it was 30 years old. Rust on everything. Lots of cleaning, sanding, priming, painting.... most every nut, bold, and fitting replaced. Until you really pressure wash out the engine bay, I’d be even be weary of putting it in my garage - again, incredibly nasty stuff.
Mark Horner
President, ZR-1 Net Registry
91 ZR-1 #2016
95 ZR-1 #21 DRM-600, LPE 385
Vette Guy is offline   Reply With Quote
Old 04-28-2020   #24
Hey Mark!
Hope you are making the most out of this crazy time.
I keep a Halguard extinguisher and Halguard claims clean agent. Is this the same kind of agent as you had experienced?
https://www.h3rperformance.com/p4234-hg100c
Old 04-28-2020   #25
Vette Guy
Vette Guy's Avatar
Default Engine Fire??
I did not have a Halguard, but the car was equipped with a Lifeline FIA certified 4 liter, 8 nozzle aqueous film forming foam system, and I carry an additional 4lb class B/C extinguisher. When I egressed the car, I didn’t know the extent of the fire and was reluctant to pull the AFFF as it would spray not only the engine, but fill the interior as well. I grabbed the hand-held and went to address the fire, knowing I can grab the second activation pull located outside the car if needed... (it’s also $500 if I pull it). I quickly extinguished the engine fire, but couldn’t get the fire out in the tunnel, which continued to flare up. The AFFF system would not have reached it either. I went through my 4lb handheld, as well as a larger extinguisher provided by a course worker to keep it at bay until the fire trucks arrived. Brett’s fire was before this, and he warned me.... but it was worst than I’d ever imagined it could be. The DEI heat shield did a great job of preventing the fiberglass from catching fire, but the rubber bellows of the ZF-6 kept the fire going until the fire trucks finished it off. They went through quite a few bottles before the big hose was finally used.
Video of the event:
https://youtu.be/gw60JxU-zYQ
So, now I carry an Element fire extinguisher, which is about the size of a flair, and does not make a mess.
Video of Element on Jay Leno’s Garage:
https://youtu.be/oBjXecsF860
Please note, it took me way too much time to realize there was fire vs. coolant, etc., and I’ve since taken the time to practice much quicker egress!
Mark Horner
91 ZR-1 #2016
Old 04-28-2020   #26
Originally Posted by Vette Guy View Post
I did not have a Halguard, but the car was equipped with a Lifeline FIA certified 4 liter, 8 nozzle aqueous film forming foam system, and I carry an additional 5lb class B/C extinguisher. When I egressed the car, I didn’t know the extent of the fire and was reluctant to pull the AFFF as it would spray not only the engine, but fill the interior as well. I grabbed the hand-held and went to address the fire, knowing I can grab the second activation pull located outside the car if needed... (it’s also $500 if I pull it). I quickly extinguished the engine fire, but couldn’t get the fire out in the tunnel, which continued to flare up. The AFFF system would not have reached it either. I went through my 5lb handheld, as well as a larger extinguisher provided by a course worker to keep it at bay until the fire trucks arrived. Brett’s fire was before this, and he warned me.... but it was worst than I’d ever imagined it could be. The DEI heat shield did a great job of preventing the fiberglass from catching fire, but the rubber bellows of the ZF-6 kept the fire going until the fire trucks finished it off. They went through quite a few bottles before the big hose was finally used.Attachment 11892Attachment 11893
Video of the event:
Sorry about the mishap.
Now that my Z is 26 years old, I started carrying a bottle of extinguisher just in case. But, not sure if 2.5 lbs bottle can do the job.
Old 04-29-2020   #27
owwdee
owwdee's Avatar
Attachment 11890Attachment 11891
Interesting and good information. I am not seeing any sign of foam or extinguishant just yet. Makes me wonder what the fire was put out with.
1991 ZR-1 #1900
Black/Black
owwdee is offline   Reply With Quote
Old 04-29-2020   #28
Vette Guy
Vette Guy's Avatar
If you don't already see corrosion, you're probably in good shape! Whew!
Mark Horner
91 ZR-1 #2016
Old 04-29-2020   #29
dredgeguy
dredgeguy's Avatar
That Element fire extinguisher is very interesting and will fit right into the center console. Appreciate the heads up on this product.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 05-17-2020   #30
owwdee
owwdee's Avatar
There’s your problem right there. Air duct is collapsing at WOT. Haha
[/ATTACH]
1991 ZR-1 #1900
Black/Black
