Old 03-28-2020   #1
Corvette95
Corvette95's Avatar
Default Thermostat and Thermostat housing and coupling
I removed my thermostat housing since I had the room, I went through the solutions, seems to be a lot of issues about which thermostat will work and which won't. I ordered a 180 degree "fail safe" thermostat from RockAuto and gasket/seal (pic below minus seal) . It looks correct as to what was posted online, but the thread was from 2013. I don't have the new thermostat in my hands yet, it is due to arrive Monday. What is so different about the LT5 thermostat? I also want to get a new plastic retainer for the housing (see pics below), and maybe a new coupler if available. There is only one bolt holding the thermostat housing on, what precautions should I take in removing the old thermostat and installing a new one? It looks pretty simple with the housing off, but have read many threads saying how difficult it is to get the housing back on with the seal in place. I know to when it comes to it, I need to get the air out, there are several different methods, I was going to try to reverse bleed it with air blowing in from the driver side and using vacuum at the tank....suggestions? See pics below...I am planning on soda blasting the housing before I put it back on. (1990)
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 03-28-2020   #2
owwdee
owwdee's Avatar
Default Re: Thermostat and Thermostat housing and coupling
For the nipple (coupler), Jerry has you covered. https://www.jerrysgaskets.com/nipple...urn-90-95-7c4/
Use care when removing this nipple. I have read about them breaking off in the housing.
Dorman 800-407 for the retainer clip. The large is 3/4”, the nipple side is 5/8”, but it is included with the new nipple from Jerry.
Putting the thermostat in is a piece of cake when the whole housing is out of the car.
Jerry used to sell the correct thermostat. Doesn’t look like he has them in stock now. I believe Stant is the correct brand, but can be a crapshoot on whether what is in the box is the right one.
Marc Haibeck has good articles on refilling the coolant.
1991 ZR-1 #1900
Black/Black
owwdee is offline   Reply With Quote
Old 03-28-2020   #3
Corvette95
Corvette95's Avatar
Thanks! I have had pretty good luck with bolts not breaking so far, only victim was the small single butterfly plate brass screws in the throttle body. Let the cam covers bolts sit with WD40 for 4 days. Letting the nipple on this sit with WD40 now.
Old 03-29-2020   #4
Post 7 - Thermostats, Fans, Water Pump, and Radiators
Old 03-29-2020   #5
Corvette95
Corvette95's Avatar
Thanks, I read that posts, but can't I use the thermostat I ordered?
Old 03-29-2020   #6
owwdee is right about being careful removing the heater hose connector on the T-stat housing. It's not made from steel. It's a fragile, pot metal and breaks easily after all these years of corrosion. Soaking in a good penetrant for a day or so and heating the housing before trying to break it loose could help. Once it is removed, you should chase the threads in the housing to clean them up. The thread is a NPT, which is a tapered thread, so run the tap deep enough to clean up the threads, but no deeper than what is necessary.
Old 03-29-2020   #7
Corvette95
Corvette95's Avatar
I don't think I have a chaser that big at home and we are under quarantine. I have been paying for UPS pick up service to send out the parts for porting to Pete, FPR for rebuild to Jagdpanzer and tensioner to Marc H
Do you know the thread size off hand, I might can get one from Amazon. (this is why I have time to work on the car right now, my business is closed)
Old 03-29-2020   #8
Corvette95
Corvette95's Avatar
I got the coupling off... used heat, it was very tight, but came off, threads look ok, would certainly run a chaser through them if I can, the 13 mm bolt that is still on the thermostat cover is being difficult. It is soaking in WD40 right now. I ad sprayed both of them yesterday afternoon and let them sit over night.
Old 03-29-2020   #9
Ccmano
Ccmano's Avatar
Be careful with the thermostats you receive from suppliers. More often that not their wrong. Only the Stant long thermostat with the cut outs in the bottom piece is correct. I actually got a wrong thermostat in a correct Stant box! Read what happened to me...
H
http://www.zr1.net/forum/showthread....824#post280824
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 03-29-2020   #10
Corvette95
Corvette95's Avatar
I read the thread, what is special about the stant other than the two cut outs, I saw the Delco one you bought, why was that not usable? I haven't located a Stant. Here is my OE one...
